* | testsuite: Use new name of test-info.h. | Christian Mauderer | 2020-07-31 | 1 | -1/+1 |
| | | | | | In RTEMS the test.h has been renamed to test-info.h to allow the new test framework to take over. | ||||
* | testsuite: A description for each test added | Moyano, Gabriel | 2020-04-09 | 1 | -0/+8 |
* | testsuite: CONFIGURE_MAXIMUM_FILE_DESCRIPTORS | Sebastian Huber | 2020-04-03 | 1 | -1/+1 |
* | testsuite: User input define added | Moyano, Gabriel | 2020-03-31 | 1 | -1/+2 |
* | testsuite: Using RTEMS tester functions at beginning and at the end of tests | Moyano, Gabriel | 2020-03-31 | 1 | -1/+4 |
| | | | | puts() was replaced with rtems_test_begin() and rtems_test_end() | ||||
* | usb01: Simplify test program | Sebastian Huber | 2016-09-28 | 8 | -1072/+124 |
* | Delete obsolete _bsd_nexus_devices | Sebastian Huber | 2014-10-08 | 1 | -10/+0 |
* | usb01: Update due to API changes | Sebastian Huber | 2014-09-30 | 1 | -2/+0 |
* | Delete rtems_bsd_initialize_with_interrupt_server | Sebastian Huber | 2013-12-20 | 1 | -1/+1 |
| | | | | Move interrupt server initialization to nexus_probe(). | ||||
* | Use floating-point tasks for tests | Sebastian Huber | 2013-12-20 | 1 | -1/+3 |
* | usb01: Remove SDHC references | Sebastian Huber | 2013-12-04 | 1 | -10/+0 |
* | usb01: Fix warning | Sebastian Huber | 2013-11-13 | 1 | -1/+0 |
* | Use extension to attach a struct thread to threads | Sebastian Huber | 2013-10-10 | 1 | -0/+2 |
| | | | | Add test thread01. | ||||
* | Move core system initialization references | Sebastian Huber | 2013-10-10 | 1 | -1/+0 |
* | Update files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 3 | -47/+4 |
| | | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | ||||
* | usb01: Correct Makefile | Joel Sherrill | 2012-07-28 | 1 | -3/+6 |
* | usb01: make Makefile follow pattern of others | Joel Sherrill | 2012-07-28 | 1 | -4/+5 |
* | Standardized Makefiles so that i386 would build correctly. | Jennifer Averett | 2012-05-16 | 1 | -23/+12 |
* | testsuite/usb01: Support multiple BSPs | Sebastian Huber | 2012-03-27 | 2 | -11/+29 |
* | e1000 driver now compiles with fewer modifications | Julien Delange | 2012-03-26 | 1 | -1/+1 |
| | | | | | | | | | | | | | - Change some include path in the e1000 drivers - Add some files from the FreeBSD source tree (modification in freebsd-to-rtems.py) - Avoid inconsistent functions declarations: the bool_t and/or boolean_t are not the same between rtems and freebsd so that a function with the prototype bool_t foobar() and another boolean_t foobar() does not compile on rtems. (see if_igb.c for example) Joel Note: These are still inconsistent on the FreeBSD side and need to be addressed by them. We will just make the prototype match the body until they give us a solution. | ||||
* | usb01 builds but does not link | Joel Sherrill | 2012-03-21 | 4 | -48/+44 |
* | USB test but closer to code in PR | Joel Sherrill | 2012-03-20 | 5 | -0/+750 |
* | Convert to UNIX CR/LF. | Joel Sherrill | 2012-03-20 | 2 | -393/+393 |
* | Compiles but we are missing test.h. | Joel Sherrill | 2012-03-20 | 1 | -1/+1 |
| | | | | Maybe it is in the PR. | ||||
* | Add USB test from Sebastian Huber with no modifications. | Joel Sherrill | 2012-03-20 | 4 | -0/+444 |
