* | testsuite: A description for each test added | Moyano, Gabriel | 2020-04-09 | 1 | -0/+9 |
* | Fix sporadic test failures via uma_timeout() | Sebastian Huber | 2018-07-26 | 1 | -1/+10 |
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Use thread name support | Sebastian Huber | 2017-01-13 | 1 | -1/+1 |
| | | | | Update #2858. | ||||
* | Directly use <sys/types.h> provided by Newlib | Sebastian Huber | 2016-05-30 | 1 | -1/+1 |
* | Add and use rtems_bsd_get_task_stack_size() | Sebastian Huber | 2015-01-20 | 1 | -1/+3 |
* | Update due to workspace allocation changes | Sebastian Huber | 2014-05-14 | 1 | -39/+38 |
* | Use floating-point tasks for tests | Sebastian Huber | 2013-12-20 | 1 | -1/+1 |
* | testsuite: Simplify tests | Sebastian Huber | 2013-11-13 | 1 | -7/+0 |
* | Rename rtems-bsd-config.h | Sebastian Huber | 2013-11-11 | 1 | -1/+1 |
| | | | | Rename rtems-bsd-config.h in rtems-bsd-kernel-space.h. | ||||
* | Use extension to attach a struct thread to threads | Sebastian Huber | 2013-10-10 | 1 | -0/+304 |
Add test thread01. |
