* | tests/termios: Fix warnings | Sebastian Huber | 2018-08-20 | 1 | -3/+11 |
* | Include missing <string.h> and <limits.h> | Sebastian Huber | 2017-08-25 | 1 | -1/+2 |
| | | | | | | | Fix warnings. Update #2132. Update #2133. | ||||
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 2 | -83/+3 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Adding test cases for FREEBSD termios support through tty | Kevin Kirspel | 2017-05-11 | 5 | -0/+1290 |
