* | Compatibility for next Newlib update | Sebastian Huber | 2019-09-25 | 1 | -0/+5 |
* | Add pselect() | Sebastian Huber | 2019-09-23 | 1 | -0/+76 |
* | test/syscalls01: Fix sporadic test failures | Sebastian Huber | 2019-09-23 | 1 | -0/+32 |
* | syscalls01: Fix for IPSEC enabled | Sebastian Huber | 2018-08-28 | 1 | -0/+5 |
* | Fix sporadic test failures via uma_timeout() | Sebastian Huber | 2018-07-26 | 1 | -12/+5 |
* | syscalls01: Fix sporadic test failures | Sebastian Huber | 2018-07-02 | 1 | -0/+14 |
* | tests/syscalls01: Fix shutdown() test | Sebastian Huber | 2017-11-10 | 1 | -1/+14 |
| | | | | The socket must be connected for a shutdown(). | ||||
* | tests/syscall01: Update error values | Sebastian Huber | 2017-11-10 | 1 | -39/+39 |
| | | | | FreeBSD changed the error values. | ||||
* | testsuite/syscalls01: Split out program01 part. | Christian Mauderer | 2016-08-02 | 1 | -194/+0 |
| | | | | | | This allows to use normal functions for sockets and similar while allowing to test the upcoming rtems_bsd_program_opan/close/... for the program part. | ||||
* | SOCKETPAIR(2): Port to RTEMS | Sebastian Huber | 2015-11-16 | 1 | -0/+48 |
* | Support sethostname() and gethostname() | Sebastian Huber | 2014-10-24 | 1 | -0/+20 |
* | SYSLOG(3): Replace implementation | Sebastian Huber | 2014-10-09 | 1 | -0/+24 |
| | | | | | Avoid potential buffer overflows on the stack. Expand the %m in the format string. | ||||
* | Disable IPsec | Sebastian Huber | 2014-09-23 | 1 | -3/+3 |
| | | | | | IPsec has a significant performance impact. Disable it for now since is only partially supported and untested. | ||||
* | UNIX(4): Import from FreeBSD | Sebastian Huber | 2014-01-16 | 1 | -1/+3 |
* | syscalls01: Include missing header file | Sebastian Huber | 2013-12-20 | 1 | -0/+1 |
* | Use floating-point tasks for tests | Sebastian Huber | 2013-12-20 | 1 | -1/+1 |
* | testsuite: Simplify tests | Sebastian Huber | 2013-11-13 | 1 | -1/+0 |
* | syscalls01: Update due to RTEMS changes | Sebastian Huber | 2013-11-04 | 1 | -1/+1 |
* | Enable INET6 | Sebastian Huber | 2013-10-31 | 1 | -1/+1 |
* | Use kqueue() and kevent() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+151 |
* | Use poll() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+75 |
* | Use select() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+75 |
* | Move program control to thread structure | Sebastian Huber | 2013-10-31 | 1 | -0/+196 |
* | Use send/recv functions from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+207 |
| | | | | Use recvfrom(), recvmsg(), sendto() and sendmsg() from FreeBSD. | ||||
* | Use socket read() and write() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+66 |
* | Use getsockname() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+55 |
* | Use getpeername() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+51 |
* | Use getsockopt() and setsockopt() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+101 |
* | Use accept() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+52 |
* | Use listen() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+55 |
* | Use connect() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+58 |
* | Use socket ioctl() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+52 |
* | Use bind() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+71 |
* | Use shutdown() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -3/+49 |
* | Add socket fstat() support | Sebastian Huber | 2013-10-31 | 1 | -0/+104 |
* | Import socket() implementation from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+310 |
Add new test syscalls01. |
