2018-07-26 | selectpollkqueue01: Invalidate file descriptor | Sebastian Huber | 1 | -0/+6 | |
This is not a functional change or a fix. | |||||
2017-08-25 | Include missing <string.h> and <limits.h> | Sebastian Huber | 1 | -1/+0 | |
Fix warnings. Update #2132. Update #2133. | |||||
2017-06-08 | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 1 | -1/+1 | |
The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | |||||
2016-12-23 | PIPE(2): Port to RTEMS | Kevin Kirspel | 1 | -2/+181 | |
2016-10-07 | testsuite: Fix warnings | Sebastian Huber | 1 | -1/+0 | |
2016-06-10 | selectpollkqueue01: Add EVFILT_USER test case | Sebastian Huber | 1 | -0/+49 | |
2013-12-20 | Use floating-point tasks for tests | Sebastian Huber | 1 | -1/+1 | |
2013-11-13 | testsuite: Simplify tests | Sebastian Huber | 1 | -5/+0 | |
2013-11-11 | Update to FreeBSD 9.2 | Sebastian Huber | 1 | -1/+1 | |
2013-10-31 | selectpollkqueue01: New test | Sebastian Huber | 1 | -0/+997 | |
