* | testsuite: A description for each test added | Moyano, Gabriel | 2020-04-09 | 1 | -0/+8 |
* | testsuite: User input define added | Moyano, Gabriel | 2020-03-31 | 1 | -0/+1 |
* | Fix warnings | Sebastian Huber | 2019-09-24 | 1 | -0/+1 |
* | media01: Reduce record item count | Sebastian Huber | 2019-08-27 | 1 | -1/+1 |
* | media01: Enable event recording | Sebastian Huber | 2019-08-26 | 1 | -0/+8 |
* | Update due to API changes | Sebastian Huber | 2019-04-11 | 1 | -1/+1 |
* | media01: Improve output messages | Sebastian Huber | 2018-09-25 | 1 | -12/+7 |
| | | | | | Use a single printf() call to avoid interference from other output. Do not print the listener argument. | ||||
* | ipsec-tools: Port libipsec, setkey and racoon. | Christian Mauderer | 2018-08-02 | 1 | -0/+9 |
| | | | | | Note that this replaces the libipsec from FreeBSD with the one provided by ipsec-tools. | ||||
* | buildset: Add minimal and everything config. | Christian Mauderer | 2018-05-03 | 1 | -3/+10 |
| | | | | | | | | | | | | This adds two new buildset configurations: One that leaves out as much features as possible and one that enables all features. For the default configuration WiFi support is now disabled. To disable IPv6 for the minimal configuration, all -DINET6 are eliminated in libbsd.py. They are now replaced by a #ifdef that checks for RTEMS_BSD_MODULE_NETINET6 instead. Close #3351. | ||||
* | Add wpa_supplicant_fork command. | Sichen Zhao | 2017-11-10 | 1 | -1/+2 |
| | | | | Add fork command for wpa supplicant to start a new task. | ||||
* | Add wpa_supplicant command in test suite. | Sichen Zhao | 2017-11-10 | 1 | -1/+2 |
| | | | | Add wpa supplicant command in media01. | ||||
* | media01: Scale with processor count | Sebastian Huber | 2017-10-20 | 1 | -2/+6 |
* | Include missing <string.h> and <limits.h> | Sebastian Huber | 2017-08-25 | 1 | -0/+1 |
| | | | | | | | Fix warnings. Update #2132. Update #2133. | ||||
* | media01: Add cpuinfo command | Sebastian Huber | 2017-03-08 | 1 | -0/+1 |
* | Update due to configuration API changes | Sebastian Huber | 2017-02-21 | 1 | -3/+1 |
* | Use thread name support | Sebastian Huber | 2017-01-13 | 1 | -1/+0 |
| | | | | Update #2858. | ||||
* | ARP(8): Port to RTEMS | Sebastian Huber | 2017-01-10 | 1 | -0/+1 |
* | VMSTAT(8): Port to RTEMS | Sebastian Huber | 2017-01-10 | 1 | -1/+2 |
* | testsuite: Fix warnings | Sebastian Huber | 2016-10-07 | 1 | -0/+1 |
* | media01: Add sysctl command | Sebastian Huber | 2016-05-06 | 1 | -0/+1 |
* | media01: Add telnetd | Sebastian Huber | 2016-04-26 | 1 | -1/+33 |
* | media01: Add mount etc. commands | Sebastian Huber | 2015-11-02 | 1 | -0/+3 |
* | media01: Add network and SMP support | Sebastian Huber | 2015-09-11 | 1 | -3/+44 |
* | media01: New test | Sebastian Huber | 2015-03-26 | 1 | -0/+160 |
