* | testsuite: Simplify tests | Sebastian Huber | 2013-11-13 | 1 | -1/+0 |
* | loopback01: Wait for client termination | Sebastian Huber | 2013-10-31 | 1 | -7/+49 |
* | loopback01: Initialize via IFCONFIG(8) | Sebastian Huber | 2013-10-31 | 1 | -23/+18 |
* | Update files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 3 | -50/+5 |
| | | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | ||||
* | loopback01/init.c: Remove junk file | Joel Sherrill | 2012-09-01 | 1 | -82/+0 |
* | loopback01: Does not include rtems specific net files | Joel Sherrill | 2012-07-27 | 3 | -2/+84 |
* | loopback01: New test from samples/loopback | Joel Sherrill | 2012-07-26 | 2 | -0/+310 |
