path: root/testsuite/init01 (follow)
* testsuite: Simplify testsSebastian Huber2013-11-131-1/+0
* Update files to match FreeBSD layoutSebastian Huber2013-10-104-115/+5
| | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests.
* Move files to match FreeBSD layoutSebastian Huber2013-10-101-85/+0
* netshell01: New test and stop using old network configuration codeJoel Sherrill2012-09-011-6/+0
| | | | | | | | The old network configuration using a data structure does not support IPV6 and does not support all of the network settings that the FreeBSD command line utilities do. Transition to using the network utilities like ifconfig, route, etc. to initialize the NIC configuration.
* init01: Add configuration structureJoel Sherrill2012-07-272-4/+27
* init01: Add init.cJoel Sherrill2012-07-271-5/+11
* Rename link01 to init01Joel Sherrill2012-07-265-0/+218
