2020-04-09 | testsuite: A description for each test added | Moyano, Gabriel | 1 | -1/+3 | |
2013-11-13 | testsuite: Simplify tests | Sebastian Huber | 1 | -1/+0 | |
2013-10-10 | Update files to match FreeBSD layout | Sebastian Huber | 4 | -115/+5 | |
Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | |||||
2013-10-10 | Move files to match FreeBSD layout | Sebastian Huber | 1 | -85/+0 | |
2012-09-01 | netshell01: New test and stop using old network configuration code | Joel Sherrill | 1 | -6/+0 | |
The old network configuration using a data structure does not support IPV6 and does not support all of the network settings that the FreeBSD command line utilities do. Transition to using the network utilities like ifconfig, route, etc. to initialize the NIC configuration. | |||||
2012-07-27 | init01: Add configuration structure | Joel Sherrill | 2 | -4/+27 | |
2012-07-27 | init01: Add init.c | Joel Sherrill | 1 | -5/+11 | |
2012-07-26 | Rename link01 to init01 | Joel Sherrill | 5 | -0/+218 | |
