* | test/commands01: Fix sporadic test failures | Sebastian Huber | 2019-06-26 | 1 | -1/+29 |
* | buildset: Add minimal and everything config. | Christian Mauderer | 2018-05-03 | 1 | -0/+15 |
| | | | | | | | | | | | | This adds two new buildset configurations: One that leaves out as much features as possible and one that enables all features. For the default configuration WiFi support is now disabled. To disable IPv6 for the minimal configuration, all -DINET6 are eliminated in libbsd.py. They are now replaced by a #ifdef that checks for RTEMS_BSD_MODULE_NETINET6 instead. Close #3351. | ||||
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | testsuite/commands01: Add wlanstats call. | Christian Mauderer | 2017-01-17 | 1 | -0/+17 |
* | Add and use RTEMS_BSD_ARGC() | Sebastian Huber | 2014-01-30 | 1 | -2/+2 |
* | testsuite: Simplify tests | Sebastian Huber | 2013-11-13 | 1 | -20/+0 |
* | commands01: Add INET6 test cases | Sebastian Huber | 2013-10-31 | 1 | -0/+51 |
* | commands01: New test | Sebastian Huber | 2013-10-31 | 1 | -0/+242 |
