* | rc_conf: Include missing header files | Sebastian Huber | 2018-05-08 | 1 | -0/+4 | |
* | buildset: Add minimal and everything config. | Christian Mauderer | 2018-05-03 | 2 | -1/+5 | |
| | | | | | | | | | | | | This adds two new buildset configurations: One that leaves out as much features as possible and one that enables all features. For the default configuration WiFi support is now disabled. To disable IPv6 for the minimal configuration, all -DINET6 are eliminated in libbsd.py. They are now replaced by a #ifdef that checks for RTEMS_BSD_MODULE_NETINET6 instead. Close #3351. | |||||
* | rtems-debugger: Remove files | Sebastian Huber | 2018-05-02 | 2 | -390/+0 | |
| | | | | | | They are now in the main RTEMS sources. Update #3419. | |||||
* | Use network services from RTEMS | Sebastian Huber | 2018-04-30 | 12 | -6213/+0 | |
| | | | | Close #3419. | |||||
* | CRYPTO(4): Port to RTEMS | Sebastian Huber | 2018-03-28 | 1 | -0/+1 | |
* | DEVFS(5): Properly initialize fp->f_cdevpriv | Sebastian Huber | 2018-03-27 | 1 | -0/+1 | |
* | vprintf: Add handler that mutes all output. | Christian Mauderer | 2018-03-23 | 2 | -0/+19 | |
| | | | | | This adds a vprintf handler that can be used to suppress all outputs of the libbsd. | |||||
* | Silence rtems_bsd_ifconfig() | Sebastian Huber | 2018-03-23 | 1 | -0/+1 | |
* | if_atsam: Add checksum offload. | Christian Mauderer | 2018-03-21 | 1 | -8/+44 | |
* | mutex: Use panic() after ISR lock release | Sebastian Huber | 2018-03-13 | 2 | -6/+25 | |
| | | | | | | Using panic() with interrupts disabled could lead to an additional error (INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT) due to a potentially blocking output. | |||||
* | dw_mmc: Properly init/reset DMA | Sebastian Huber | 2018-02-06 | 1 | -12/+27 | |
* | dw_mmc: Add MMCBR_IVAR_TIMING | Sebastian Huber | 2018-02-06 | 1 | -0/+6 | |
* | Add device tree support for Altera/Intel Cyclone V | Sebastian Huber | 2018-02-06 | 4 | -214/+44 | |
| | | | | Close #3290. | |||||
* | linux/percpu.h: Fix for uni-processor config | Sebastian Huber | 2018-02-05 | 1 | -2/+3 | |
* | termios: Update due to API changes | Sebastian Huber | 2018-02-05 | 1 | -23/+8 | |
| | | | | Update #2843. | |||||
* | sdk_dpaa: Port to RTEMS | Sebastian Huber | 2018-01-23 | 6 | -0/+218 | |
| | | | | Update #3277. | |||||
* | dpaa: QMan portal only initialization | Sebastian Huber | 2018-01-23 | 1 | -0/+4 | |
* | dpaa: Add and use SDK_DPAA_COMPAT_STATIC | Sebastian Huber | 2018-01-23 | 1 | -0/+9 | |
* | dpaa: Remove unused configuration defines | Sebastian Huber | 2018-01-23 | 1 | -9/+0 | |
* | linux/of_irq.h: Generalize of_irq_to_resource() | Sebastian Huber | 2018-01-23 | 1 | -10/+51 | |
| | | | | | | Determine interrupt cells via device tree. Update #3277. | |||||
* | linux/of_address.h: of_address_to_resource() | Sebastian Huber | 2018-01-23 | 2 | -16/+8 | |
| | | | | | | Translate address in of_address_to_resource(). Update #3277. | |||||
* | linux/of_address.h: Add of_translate_address() | Sebastian Huber | 2018-01-23 | 3 | -3/+81 | |
* | linux/of.h: Add of_find_node_by_path() | Sebastian Huber | 2018-01-23 | 2 | -0/+19 | |
* | linux/of.h: Add of_read_number() | Sebastian Huber | 2018-01-23 | 2 | -0/+18 | |
* | linux/of.h: Add of_n_size_cells() | Sebastian Huber | 2018-01-23 | 2 | -0/+9 | |
* | linux/of.h: Add of_n_addr_cells() | Sebastian Huber | 2018-01-23 | 2 | -0/+9 | |
* | linux/sort.h: New file | Sebastian Huber | 2018-01-23 | 1 | -0/+49 | |
* | linux/smp.h: Avoid function call overhead | Sebastian Huber | 2018-01-23 | 1 | -1/+1 | |
* | linux/compiler.h: Define __cold | Sebastian Huber | 2018-01-23 | 1 | -0/+1 | |
* | Add rtems_bsd_ifconfig() | Sebastian Huber | 2018-01-23 | 2 | -0/+91 | |
* | ehci_mpc83xx.c: Fix for qoriq hypervisor guest | Sebastian Huber | 2018-01-19 | 1 | -1/+2 | |
* | Add rtems_bsd_initialize_dhcp() | Sebastian Huber | 2017-12-05 | 2 | -0/+137 | |
* | Revert "RWLOCK(9): Add reader/writer lock implementation" | Sebastian Huber | 2017-11-17 | 4 | -749/+30 | |
| | | | | | | This was accidentally committed. This reverts commit 97a98f6cd767b3a68279890488c7b451788f84f4. | |||||
* | Revert "SX(9): Implement with reader/writer lock" | Sebastian Huber | 2017-11-17 | 1 | -93/+28 | |
| | | | | | | This was accidentally committed. This reverts commit cc7a8d87e7307db738bf39ab1ca3ce1053f1c163. | |||||
* | SX(9): Implement with reader/writer lock | Sebastian Huber | 2017-11-16 | 1 | -28/+93 | |
* | RWLOCK(9): Add reader/writer lock implementation | Sebastian Huber | 2017-11-16 | 4 | -30/+749 | |
* | LOCKING(9): Remove dead code (DDB) | Sebastian Huber | 2017-11-16 | 3 | -12/+0 | |
* | LOCKING(9): Remove dead code (KDTRACE_HOOKS) | Sebastian Huber | 2017-11-16 | 3 | -59/+0 | |
* | LOCKING(9): Update to current FreeBSD version | Sebastian Huber | 2017-11-16 | 4 | -81/+115 | |
* | at91_mci: Port to RTEMS and adapt for atsam. | Christian Mauderer | 2017-11-10 | 2 | -0/+21 | |
* | saf1761_otg: Port to RTEMS. | Christian Mauderer | 2017-11-10 | 1 | -0/+21 | |
* | wpa_supplicant: Add lock. | Christian Mauderer | 2017-11-10 | 2 | -0/+123 | |
* | wpa_supplicant: Move forking command into own file. | Christian Mauderer | 2017-11-10 | 1 | -0/+64 | |
| | | | | | The malloc wrapper must not be disabled. Therefore the command that uses malloc without a wrapper has to live in another file. | |||||
* | Add wpa_supplicant_fork command. | Sichen Zhao | 2017-11-10 | 3 | -0/+40 | |
| | | | | Add fork command for wpa supplicant to start a new task. | |||||
* | Port wpa supplicant to RTEMS. | Sichen Zhao | 2017-11-10 | 6 | -0/+130 | |
| | | | | Add wpa_supplicant lib support and shell command support in RTEMS. | |||||
* | Port BBB sd driver files to RTEMS. | Sichen Zhao | 2017-11-10 | 6 | -0/+522 | |
| | | | | So BBB can mount and read eMMC and SD card. | |||||
* | Add rtems_bsd_ifconfig_lo0() | Sebastian Huber | 2017-11-10 | 2 | -0/+84 | |
* | Fix general PowerPC build | Sebastian Huber | 2017-10-26 | 1 | -0/+8 | |
* | rtems-bsd-mutex: Update due to API changes | Sebastian Huber | 2017-10-24 | 1 | -2/+1 | |
| | | | | Update #3117. | |||||
* | dpaa: Use only one FMan MAC SGT zone | Sebastian Huber | 2017-10-23 | 2 | -17/+19 | |
