Since the epoch call callbacks may lock/unlock a mutex the callbacks must be
called from within thread context with thread dispatching enabled. Use thread
pinning to ensure that the calling thread stays on the right processor. Use
the interrupt server to ensure the thread context for the epoch drain.
Use the PER_CPU_DATA_NEED_INITIALIZATION() macro if necessary to request an
initialization of the per-CPU data.
Changed nfs_utime() to nfs_utimens(), changed the arguments to use
a timespec array instead of individual variables for access and
modified time.
Updates #4400
Adds "rtems,path" as an additional bus path for the i2c driver.
Previously the bus path was provided in "rtems,i2c-path" property
only.
Possible data sources for SD driver:
- mmc_sd_switch():
- length: 64 byte;
- buffer on stack
- mmc_test_bus_width():
- length: 4 or 8 byte
- buffer in program memory or on stack
- mmc_app_send_scr():
- length: 8 byte
- buffer from device ivar structure
- mmc_app_sd_status():
- length: 64 byte
- mmc_send_ext_csd():
- length: MMC_EXTCSD_SIZE = 512
- rtems_bsd_mmcsd_disk_read_write():
- length: depends on read
- buffer from rtems_blkdev buffer -> already aligned
- mmcsd_ioctl_cmd():
- length: depends on call
- buffer malloced, not aligned -> patched in RTEMS
So the problematic buffers are only the ones up to 512 bytes. Copy these data
into a buffer to avoid that problem.
This reverts commit 1b07480ddc93c10777eff5072e7621ed0c96d30c.
The files have been taken from RTEMS repository with head commit at
bd9e45d91f77657445400bc2c814f251c9e37cef
Update #4372
The TI driver has been moved to RTEMS so the driver can be removed
from libBSD.
The following files have been removed from libBSD and moved to
RTEMS.
1) ti/am335x/am335x_scm_padconf.c
2) ti/am335x/am335x_scm_padconf.h
3) ti/ti_pinmux.c
4) ti/ti_pinmux.h
Update #3784
Update #4180
Update #3910.
Update #3910.
Update #3910.
Close #4164.
Update #4164.
- The files in the i386 directory have been moved to common x86 directories by FreeBSD:
- freebsd/sys/i386/include/machine/bus.h
- freebsd/sys/x86/include/machine/legacyvar.h
- freebsd/sys/x86/include/machine/specialreg.h
- Add header files in rtemsbsd directory to direct compiler to new files
At least the powerpc C++ compiler defines currently _GNU_SOURCE due to a GCC
configuration error. This leads to conflicting qsort_r() definitions.
As a workaround undefine _GNU_SOURCE for this C++ compatibility test file.
Update #4078.
In serporidok use the same structures used to hand over to the XDR
encode/decode routines. We must not mix packed and unpacked structures.
Close #4025.
Remove superfluous <bsp.h> include.
That option makes problems with some drivers because the buffers are not
allways cache line aligned.
Update 3869
The busdma shouldn't try to flush or invalidate cache in a nocache area.
Some targets support only flushing or invalidating complete cache lines.
In this cases misaligned buffers might lead to unexpected results. This
patch adds a flag that allows drivers to signal to the bus dma driver
that it is OK to round a buffer to the next full cache line. That's for
example necessary if a driver wants to send out 14 byte via a USB DMA.
Only the driver knows whether these 14 bytes are located in an otherwise
unused cache line aligned buffer.
Update 3869
There is a bug in the #ifdef regarding FDT so this file hasn't been
compiled. If that bug is solved, the driver doesn't work for some other
reason.
With the FDT-bug the driver hasn't been used by anyone. So just remove
it again.
Update #3869.
Update #3869.
Update #3869.
Some BSPs have a cache-coherent memory area, however, it should not be
used for the USB controller.
Aviod conflicts with application events.
- Update imported files to compile rtems-libbsd for i386 based BSPs
- Currently does not support the option "dev_nic_e1000 = on"
Update #3821.
Update #3821.
Update #3821.
Git mirror commit 6b0307a0a5184339393f555d5d424190d8a8277a.
