2019-08-11 | Pinmux: Port to RTEMS | Vijay Kumar Banerjee | 4 | -0/+77 | |
2019-07-27 | Add mmap | Vijay Kumar Banerjee | 2 | -0/+40 | |
2019-07-09 | EPOCH(9): Add epoch_drain_callbacks() | Sebastian Huber | 2 | -2/+88 | |
2019-07-09 | EPOCH(9): Avoid inline functions | Sebastian Huber | 2 | -27/+35 | |
FreeBSD changed the epoch_enter() and epoch_exit() inline functions into proper functions after a performance analysis to avoid code bloat. | |||||
2019-07-05 | SLEEPQUEUE(9): Fix timeout handling | Sebastian Huber | 2 | -0/+4 | |
2019-06-29 | i2c tool : port to RTEMS | Vijay Kumar Banerjee | 3 | -0/+39 | |
2019-06-29 | Add rtems i2c adaptation layer | Vijay Kumar Banerjee | 1 | -0/+231 | |
2019-06-29 | iicbus: port to RTEMS | Vijay Kumar Banerjee | 4 | -0/+275 | |
2019-06-13 | if_atsam: Remove WDT_Disable() | Sebastian Huber | 1 | -3/+0 | |
The watchdog timer (WDT) can be configure only once. Do not touch it in the BSP since the application may want to use it. | |||||
2019-06-05 | Add RTEMS-specific getcredhostuuid() | Sebastian Huber | 2 | -11/+29 | |
2019-05-21 | Use _SMP_Unicast_action() | Sebastian Huber | 2 | -8/+2 | |
It is a bit more efficient. | |||||
2019-05-15 | Update due to API changes | Sebastian Huber | 1 | -5/+3 | |
Close #3749. | |||||
2019-05-15 | Separate libbsd and RTEMS clock ticks | Sebastian Huber | 3 | -12/+11 | |
2019-05-13 | Include missing <stdlib.h> to fix warnings | Sebastian Huber | 1 | -0/+1 | |
2019-05-13 | Remove unused maxusers | Sebastian Huber | 2 | -3/+0 | |
2019-05-13 | Remove jail/prison functions from namespace | Sebastian Huber | 1 | -21/+0 | |
2019-05-13 | Remove dangerous weak definition of getentropy() | Sebastian Huber | 1 | -12/+0 | |
All BSP supporting libbsd should provide this function. | |||||
2019-05-13 | usb: Undefine USB_DEBUG | Sebastian Huber | 1 | -1/+1 | |
In contrast to some other USB options which use 0/1 values, the USB_DEBUG uses defined/undefined to enable/disable the USB debug support. | |||||
2019-05-13 | Add wrapper for abort() | Sebastian Huber | 1 | -2/+7 | |
2019-05-13 | Add USB mass storage only build set | Sebastian Huber | 1 | -0/+4 | |
2019-05-13 | Use static inline functions for jail and prison | Sebastian Huber | 1 | -230/+0 | |
This helps the compiler to optimize away dead code. | |||||
2019-05-13 | Fix zero-copy mbuf support | Sebastian Huber | 2 | -4/+2 | |
In 2017 there was a change in the mbuf API. | |||||
2019-04-11 | Update due to API changes | Sebastian Huber | 5 | -9/+9 | |
2019-03-29 | nfsclient: Fix for 64-bit targets | Sebastian Huber | 1 | -1/+8 | |
The use of the serporid structure with several embedded unions to split up the specific NFS request/response structures is quite a hack. It breaks on 64-bit targets due to the presence of pointer members which affect the overall alignment. | |||||
2019-03-29 | Revert "Add BURN_BRIDGES global kernel option" | Sebastian Huber | 1 | -5/+0 | |
This reverts commit 0904e3371406d2775cba848da441e00fd1ef1ef6. | |||||
2019-03-28 | Add BURN_BRIDGES global kernel option | Sebastian Huber | 1 | -0/+5 | |
2019-03-27 | bin/openssl: Port to RTEMS. | Christian Mauderer | 3 | -0/+43 | |
2019-03-01 | Remove unused file | Sebastian Huber | 1 | -224/+0 | |
2019-02-18 | Build C++ kernel-space compatibility file | Sebastian Huber | 1 | -2/+3 | |
2019-02-18 | Fix atomic_load_32() | Sebastian Huber | 1 | -1/+1 | |
2019-02-12 | Remove <linux/rbtree.h> | Sebastian Huber | 1 | -146/+0 | |
It is already provided by RTEMS. | |||||
2019-02-12 | Remove obsolete <rtems/pty.h> | Sebastian Huber | 1 | -68/+0 | |
2019-02-12 | mghttpd: Remove | Sebastian Huber | 2 | -5907/+0 | |
The mghttpd is already provided by RTEMS. | |||||
2019-02-12 | ZONE(9): Fix UMA_PCPU_ALLOC_SIZE | Sebastian Huber | 1 | -2/+2 | |
Using CACHE_LINE_SIZE for UMA_PCPU_ALLOC_SIZE was a huge memory waste since the backend memory allocator is page based. | |||||
2019-02-11 | atomic.h: Add atomic_fetchadd_64() | Sebastian Huber | 1 | -0/+26 | |
2019-02-11 | atomic.h: Add atomic_load_32() | Sebastian Huber | 1 | -0/+21 | |
2019-01-22 | Fix INVARIANTS support | Sebastian Huber | 2 | -2/+35 | |
2019-01-15 | dpaa: Use if_transmit instead of legacy if_start | Sebastian Huber | 1 | -82/+65 | |
This avoids a lock contention on the send queue. | |||||
2019-01-15 | dpaa: Fix FMan MAC SGT zone alignment | Sebastian Huber | 1 | -1/+1 | |
2018-12-20 | Update rtems-bsd-kernel-namespace.h | Sebastian Huber | 1 | -1/+26 | |
2018-12-20 | Update to FreeBSD head 2018-12-20 | Sebastian Huber | 5 | -30/+177 | |
Git mirror commit 19a6ceb89dbacf74697d493e48c388767126d418. It includes an update of wpa_supplicant to version 2.7. It includes an update of the OpenSSL baseline to version 1.1.1a. Update #3472. | |||||
2018-12-20 | freebsd/if_cpsw: Port. | Christian Mauderer | 2 | -0/+2 | |
2018-12-20 | Fix locking issue in epoch_sysinit() | Sebastian Huber | 1 | -0/+4 | |
The _Watchdog_Per_CPU_insert_ticks() assumes that interrupts are disabled. | |||||
2018-11-15 | Update to FreeBSD head 2018-11-15 | Sebastian Huber | 3 | -577/+592 | |
Git mirror commit a18b0830c4be01b39489a891b63d6023ada6358a. Update #3472. | |||||
2018-11-15 | Disable or make static kern_* functions | Sebastian Huber | 1 | -9/+0 | |
2018-11-15 | mutex: Avoid NULL pointer access in panic() | Sebastian Huber | 1 | -1/+2 | |
2018-11-15 | Fix locking issue in epoch_watchdog() | Sebastian Huber | 1 | -0/+3 | |
2018-11-13 | Include missing <sys/types.h> | Sebastian Huber | 1 | -0/+1 | |
Update #3598. | |||||
2018-10-25 | Update to FreeBSD head 2018-10-23 | Sebastian Huber | 3 | -0/+14 | |
Git mirror commit 59f44d20be3f99d181ca742e636d45fc39ec982b. This commit updates OpenSSL to version 1.1.1. This required an update of racoon which uses some internal stuff from OpenSSL and seems to be mostly unmaintained, e.g. there is update in the FreeBSD ports to cope with OpenSSL 1.1.1. Update #3472. | |||||
2018-10-23 | Fix redefinition warnings | Sebastian Huber | 1 | -4/+0 | |
