Update #3525.
Update #3525.
Update #3525.
Some device drivers (e.g. MMC) need a complex intialization with working
callouts. Remove the dummy CONFIG_INTRHOOK() implementation and replace
it with the real one from FreeBSD. Make sure TIMEOUT(9) services work
at this point.
Update #3525.
With a write-back cache dirty cache lines may be evicted which could
overwrite new data.
Close #3523.
Update #3523.
Update #3523.
Update #3523.
Imported from RTEMS commit 1fe1b820de02c274c2b2b3431340152734ee9fb6
(2018-09-12).
Update #3523.
Git mirror commit 6c2192b1ef8c50788c751f878552526800b1e319.
Update #3472.
Git mirror commit fb63610a69b0eb7f69a201ba05c4c1a7a2739cf9.
Update #3472.
Git mirror commit 8dfb1ccc26d1cea7e2529303003ff61f9f1784c4.
Update #3472.
Git mirror commit d079ae0442af8fa3cfd6d7ede190d04e64a2c0d4.
Update #3472.
Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266.
Update #3472.
Git mirror commit b2f0376b45428f13151d229c5ae9d4d8f74acbd1.
Update #3472.
Git mirror commit f5002f5e5f78cae9f0269d812dc0aedb0339312c.
Update #3472.
Git mirror commit dfb26efac4ce9101dda240e94d9ab53f80a9e131.
Update #3472.
The sources can be obtained via:
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-765.1.2.tar.gz
Move mDNS_StartResolveService() and mDNS_StopResolveService() to an
RTEMS-specific file (rtemsbsd/mdns/mDNSResolveService.c) using the
v576.30.4 implementation. Apple removed these functions without
explanation.
Update #3522.
The current stack size was insuffient on a test run of the foobarclient
test program.
Update #3522.
This header file is provided by RTEMS.
The number of callouts is a compile-time constant in libbsd. Use this
in struct callout_cpu and avoid dynamic allocation of tables. This
signficantly reduces the count of load instructions in the callout
handling.
This allows to initialize other basic services which depend on the
interrupt server.
This avoids false link-time dependencies.
Do not overwrite the device ivars used by the simplebus. Use
unspecified unit number for child device.
Move the kernel space content of some Newlib provided header files to
RTEMS and libbsd. This allows to use the Newlib provided header files
with different FreeBSD baselines.
Update #3472.
This firewall was not ported to RTEMS and is just dead code which may
make trouble during FreeBSD baseline updates. It also increased the
compile-time of the library for nothing.
Update #3472.
Update #3472.
Changes correspond to FreeBSD commit:
"Make timespecadd(3) and friends public
The timespecadd(3) family of macros were imported from NetBSD back in
r35029. However, they were initially guarded by #ifdef _KERNEL. In the
meantime, we have grown at least 28 syscalls that use timespecs in some
way, leading many programs both inside and outside of the base system to
redefine those macros. It's better just to make the definitions public.
Our kernel currently defines two-argument versions of timespecadd and
timespecsub. NetBSD, OpenBSD, and FreeDesktop.org's libbsd, however, define
three-argument versions. Solaris also defines a three-argument version, but
only in its kernel. This revision changes our definition to match the
common three-argument version.
Bump _FreeBSD_version due to the breaking KPI change.
Discussed with: cem, jilles, ian, bde
Differential Revision: https://reviews.freebsd.org/D14725"
Update #3472.
The cloned interfaces have to be set up befor the interface list is
created. Otherwise it's not possible to configure a cloned interface
with a `ifconfig_gifX` line.
Note that this replaces the libipsec from FreeBSD with the one provided
by ipsec-tools.
This ports the kernel space parts for ipsec and adds them to the
everything-buildset.
The getsockaddr() function is used to allocate a struct sockaddr of the
right length and initialize it with userspace provided data. It is used
for the connect(), bind() and sendit() family functions. In particular,
the sendit() function is used by the UDP send functions. This means
each UDP send needs a malloc() and free() invocation. This is a
performance problem in RTEMS (first-fit heap) and may lead to heap
fragmentation. Replace the malloc() allocation with a stack allocation.
This requires SOCK_MAXADDRLEN (= 255) of additional stack space for
libbsd.
A further optimization would be to get rid of the stack copy of the
socket address. However, this would require to check each consumer of
the address to ensure that it is not modified.
Update #3351.
Use it throughout to start the DHCP client (dhcpcd).
The dhcpcd will create the directories on its own.
This adds two new buildset configurations: One that leaves out as much
features as possible and one that enables all features. For the default
configuration WiFi support is now disabled.
To disable IPv6 for the minimal configuration, all -DINET6 are
eliminated in libbsd.py. They are now replaced by a #ifdef that checks
for RTEMS_BSD_MODULE_NETINET6 instead.
Close #3351.
They are now in the main RTEMS sources.
Update #3419.
Close #3419.
This adds a vprintf handler that can be used to suppress all outputs of
the libbsd.
