* | Modified copyright on rtems-bsd-xxx files to be consistant with FreeBSD ↵ | Jennifer Averett | 2012-05-08 | 35 | -124/+703 |
| | | | | copyright. | ||||
* | Added stubs for funsetown() and fsetown() | Jennifer Averett | 2012-05-02 | 1 | -0/+51 |
* | Modifed sleep queue to be priority based and added the wakeup_one method. | Jennifer Averett | 2012-05-01 | 1 | -1/+22 |
* | Remove proc0 creation | Sebastian Huber | 2012-04-26 | 3 | -11/+4 |
* | Merged rtems-bsd-uma.c back into uma_core.c | Jennifer Averett | 2012-04-19 | 1 | -2796/+0 |
| | | | | The majority of this file was the same as the freebsd file uma_core.c. | ||||
* | Add SYSINIT for RTEMS SMP variable initialization | Joel Sherrill | 2012-04-19 | 1 | -2/+3 |
* | Merged the rtems version of resource back to kern_resource and added method ↵ | Jennifer Averett | 2012-04-18 | 1 | -174/+0 |
| | | | | to resolve linker errors. | ||||
* | Added an RTEMS specific version of routines needed from copyinout.c | Jennifer Averett | 2012-04-18 | 1 | -0/+31 |
* | Move M_IOV to reduce dependencies | Sebastian Huber | 2012-04-18 | 2 | -2/+2 |
* | Added empty method for pgsigio. | Jennifer Averett | 2012-04-18 | 1 | -0/+6 |
* | Use format of other RTEMS machine header files | Sebastian Huber | 2012-04-18 | 1 | -11/+8 |
* | Move __bswap64() | Sebastian Huber | 2012-04-18 | 1 | -4/+37 |
| | | | | | Add copyright notice of FreeBSD "sys/powerpc/include/endian.h". Change license to BSD. | ||||
* | Moved uio_yield implementation into bsd file. | Jennifer Averett | 2012-04-18 | 1 | -79/+0 |
* | Moved rtems-bsd-cyclecount.c to cpu.h | Jennifer Averett | 2012-04-18 | 1 | -4/+9 |
* | Add BUS_DMA(9) support for mbufs | Sebastian Huber | 2012-04-18 | 3 | -32/+218 |
* | Removed file | Sebastian Huber | 2012-04-18 | 1 | -242/+0 |
| | | | | | | | In this file the copyright information was wrong. It claimed to be copyrighted by embedded brains GmbH, but this is not the case. It seems to be a partial copy from FreeBSD "kern/kern_prot.c" with format changes. | ||||
* | Added rtems version of get_cyclecount(). | Jennifer Averett | 2012-04-17 | 1 | -2/+2 |
* | Added rtems unique version of uio_yield() | Jennifer Averett | 2012-04-17 | 1 | -0/+79 |
* | Include proper headers, format and use vprintk() | Sebastian Huber | 2012-04-17 | 1 | -7/+8 |
* | in_cksum() support for SPARC | Sebastian Huber | 2012-04-17 | 1 | -0/+77 |
* | Added get_cyclecount() method. | Jennifer Averett | 2012-04-16 | 1 | -0/+29 |
* | moved taskqueue_enqueue_fast from a define to a method to resolve linker errors. | Jennifer Averett | 2012-04-16 | 2 | -2/+6 |
* | Added _rw_try_upgrade & _rw_try_upgrade to resolve linker errors. | Jennifer Averett | 2012-04-16 | 1 | -0/+20 |
* | Implemented a version of rmlock using rwlock. | Jennifer Averett | 2012-04-16 | 3 | -93/+112 |
* | Added prison_check_af and jailed methods. | Jennifer Averett | 2012-04-05 | 1 | -0/+21 |
* | Add SYSCTL_NODE(_security,...,_bsd,...) | Joel Sherrill | 2012-04-04 | 1 | -0/+2 |
* | Add tvtohz() implementation in new file | Joel Sherrill | 2012-04-04 | 1 | -0/+38 |
* | Add hogticks | Joel Sherrill | 2012-04-04 | 2 | -0/+2 |
* | rtems-bsd-sync.c: Add __RTEMS_VIOLATE_KERNEL_VISIBILITY__ | Joel Sherrill | 2012-04-04 | 1 | -0/+7 |
* | Added _bsd_realloc method. | Jennifer Averett | 2012-04-04 | 1 | -0/+14 |
* | Added empty prison_check method to resolve linker error with RealTek Nic. | Jennifer Averett | 2012-04-04 | 1 | -0/+8 |
* | Added methods to resolve linker errors. | Jennifer Averett | 2012-04-02 | 1 | -0/+24 |
* | Added two prison methods to resolve linker errors. | Jennifer Averett | 2012-04-02 | 1 | -0/+27 |
* | Added Methods and stub file to remove warnings when linking with RealTek Nic. | Jennifer Averett | 2012-03-30 | 1 | -0/+153 |
* | Resolve warnings from taskqueue when linking with RealTek Nic. | Jennifer Averett | 2012-03-29 | 2 | -1/+101 |
* | Added log and prison methods to resolve linker errors for RealTek Nic. | Jennifer Averett | 2012-03-28 | 2 | -0/+49 |
* | Remove dummy symbols in link01 test | Joel Sherrill | 2012-03-27 | 3 | -11/+49 |
| | | | | | + add symbol where needed + use as much as possible from rtems-bsd-symbols.c | ||||
* | Added empty/defaulted prison methods to for linking RealTek Nic. | Jennifer Averett | 2012-03-27 | 1 | -0/+109 |
* | Moved prison_free and prison_hold to rtems-bsd-jail.c | Jennifer Averett | 2012-03-27 | 1 | -1/+6 |
* | Add bootverbose | Joel Sherrill | 2012-03-27 | 1 | -0/+2 |
* | Use new block device API | Sebastian Huber | 2012-03-26 | 1 | -23/+9 |
* | New USB device specific controller files | Sebastian Huber | 2012-03-26 | 4 | -359/+1121 |
* | Use new fsync_or_fdatasync default | Julien Delange | 2012-03-23 | 1 | -2/+3 |
* | Added maxfiles, maxfilesperproc, cold, and dpcpu_off variables. | Jennifer Averett | 2012-03-23 | 1 | -0/+5 |
* | Add M_IP6... symbols to resolve linker errors using the RealTek Nic. | Jennifer Averett | 2012-03-23 | 1 | -0/+3 |
* | Added smp specific variables to resolve linker errors with RealTek Nic. | Jennifer Averett | 2012-03-22 | 1 | -2/+12 |
* | Added taskqueue to resolve linking issues with the RealTek Nic. | Jennifer Averett | 2012-03-22 | 2 | -0/+411 |
* | Add smp variables used by e1000 and remove unneeded ifdefs | Joel Sherrill | 2012-03-22 | 1 | -0/+40 |
| | | | | | + added machine/smp.h as empty file + added rtems-bsd-smp.c for a few variables which were needed | ||||
* | Add kthread_suspend name mapping | Joel Sherrill | 2012-03-21 | 1 | -0/+1 |
* | Add include of refcount.h to get static methods. | Jennifer Averett | 2012-03-15 | 1 | -0/+1 |
