* | if_stmac: Add driver for STM32H7 ethernet module | Sebastian Huber | 2020-10-27 | 2 | -0/+1013 |
| | | | | Update #3910. | ||||
* | NVD(4): Fix logical block count calculation | Sebastian Huber | 2020-10-27 | 1 | -4/+5 |
| | | | | Close #4164. | ||||
* | NVD(4): Fix NULL pointer access in nvd_sync() | Sebastian Huber | 2020-10-27 | 1 | -14/+14 |
| | | | | Update #4164. | ||||
* | powerpc/nexus: Add legacy PCI support to PowerPC Motorola Shared BSP family | Chris Johns | 2020-10-26 | 3 | -1/+9 |
* | tsc_lpc32xx.c: Update due to API changes | Sebastian Huber | 2020-09-23 | 1 | -5/+7 |
* | linux/crc32.h: Update due to API changes | Sebastian Huber | 2020-09-22 | 1 | -1/+1 |
* | linux/genalloc.h: Update due to API changes | Sebastian Huber | 2020-09-21 | 1 | -1/+1 |
* | i386: Delete old machine dependent files | Jan Sommer | 2020-09-16 | 1 | -145/+1 |
| | | | | | | | | - The files in the i386 directory have been moved to common x86 directories by FreeBSD: - freebsd/sys/i386/include/machine/bus.h - freebsd/sys/x86/include/machine/legacyvar.h - freebsd/sys/x86/include/machine/specialreg.h - Add header files in rtemsbsd directory to direct compiler to new files | ||||
* | rtems-bsd-cxx: Undefine _GNU_SOURCE | Sebastian Huber | 2020-09-14 | 1 | -0/+1 |
| | | | | | | | | | At least the powerpc C++ compiler defines currently _GNU_SOURCE due to a GCC configuration error. This leads to conflicting qsort_r() definitions. As a workaround undefine _GNU_SOURCE for this C++ compatibility test file. Update #4078. | ||||
* | ifmcstat: Port to RTEMS | Sebastian Huber | 2020-09-10 | 3 | -0/+42 |
* | nfsclient: Next attempt to fix 64-bit targets | Sebastian Huber | 2020-08-18 | 1 | -62/+27 |
| | | | | | | | In serporidok use the same structures used to hand over to the XDR encode/decode routines. We must not mix packed and unpacked structures. Close #4025. | ||||
* | Fix linker errors with minimal build set | Sebastian Huber | 2020-08-06 | 1 | -0/+5 |
* | Conditionally include <bsp/linker-symbols.h> | Sebastian Huber | 2020-08-05 | 1 | -2/+4 |
| | | | | Remove superfluous <bsp.h> include. | ||||
* | imx: Don't use USB_NEED_BUSDMA_COHERENT_ALLOC | Christian Mauderer | 2020-07-29 | 1 | -1/+1 |
| | | | | | | | That option makes problems with some drivers because the buffers are not allways cache line aligned. Update 3869 | ||||
* | busdma: Don't sync nocache memory on ARM | Christian Mauderer | 2020-07-29 | 1 | -0/+8 |
| | | | | The busdma shouldn't try to flush or invalidate cache in a nocache area. | ||||
* | busdma: Option to round to cache lines on sync | Christian Mauderer | 2020-07-29 | 3 | -0/+15 |
| | | | | | | | | | | Some targets support only flushing or invalidating complete cache lines. In this cases misaligned buffers might lead to unexpected results. This patch adds a flag that allows drivers to signal to the bus dma driver that it is OK to round a buffer to the next full cache line. That's for example necessary if a driver wants to send out 14 byte via a USB DMA. Only the driver knows whether these 14 bytes are located in an otherwise unused cache line aligned buffer. | ||||
* | imx: Use RTEMS GPIO driver instead of FreeBSD one | Christian Mauderer | 2020-07-29 | 2 | -1/+307 |
| | | | | Update 3869 | ||||
* | gpioregulator: Remove. | Christian Mauderer | 2020-07-29 | 1 | -1/+0 |
| | | | | | | | | | There is a bug in the #ifdef regarding FDT so this file hasn't been compiled. If that bug is solved, the driver doesn't work for some other reason. With the FDT-bug the driver hasn't been used by anyone. So just remove it again. | ||||
* | ehci_imx: Add to build. | Christian Mauderer | 2020-04-15 | 1 | -0/+5 |
* | Add support for i.mx cache. | Christian Mauderer | 2020-04-15 | 1 | -1/+1 |
| | | | | Update #3869. | ||||
* | regulator: Add to build. | Christian Mauderer | 2020-04-15 | 5 | -0/+225 |
* | imx6_ccm: Add and build module. | Christian Mauderer | 2020-04-15 | 1 | -0/+2 |
* | usb_busdma: Add USB_NEED_BUSDMA_COHERENT_ALLOC | Sebastian Huber | 2020-04-15 | 1 | -0/+5 |
| | | | | | Some BSPs have a cache-coherent memory area, however, it should not be used for the USB controller. | ||||
* | nfsclient: Use a system event for RPC | Sebastian Huber | 2020-03-18 | 1 | -6/+6 |
| | | | | Aviod conflicts with application events. | ||||
* | i386: Port to RTEMS | Jan Sommer | 2020-02-10 | 6 | -0/+2401 |
| | | | | | - Update imported files to compile rtems-libbsd for i386 based BSPs - Currently does not support the option "dev_nic_e1000 = on" | ||||
* | NVMECONTROL(8): Port to RTEMS | Sebastian Huber | 2019-11-13 | 3 | -0/+39 |
| | | | | Update #3821. | ||||
* | NVD(4): Add RTEMS-specific NVMe disk driver | Sebastian Huber | 2019-11-13 | 1 | -0/+341 |
* | NVME(4): Port to RTEMS | Sebastian Huber | 2019-11-13 | 1 | -0/+0 |
* | Update to FreeBSD head 2019-09-24 | Sebastian Huber | 2019-11-13 | 12 | -28/+545 |
| | | | | Git mirror commit 6b0307a0a5184339393f555d5d424190d8a8277a. | ||||
* | Add support for EARLY_COUNTER | Sebastian Huber | 2019-09-25 | 1 | -0/+10 |
* | Remove obsolete header files | Sebastian Huber | 2019-09-24 | 1 | -1/+0 |
* | Compatibility for next Newlib update | Sebastian Huber | 2019-09-24 | 1 | -0/+4 |
* | Fix pgsigio() warnings | Sebastian Huber | 2019-09-24 | 2 | -51/+0 |
* | nexus: Avoid NULL pointer access | Sebastian Huber | 2019-09-23 | 1 | -1/+4 |
* | C++ compatiblity for kernel space header | Sebastian Huber | 2019-09-23 | 1 | -0/+8 |
* | Add wrapper for strndup() | Sebastian Huber | 2019-09-11 | 3 | -9/+31 |
* | rtemsbsd: remove dead code fb.c | Vijay Kumar Banerjee | 2019-08-31 | 1 | -2/+0 |
* | atomic.h: Add atomic_load_long() | Sebastian Huber | 2019-08-27 | 1 | -0/+21 |
* | rtems/rtems-kernel-nexus.c: LibBSD init now uses all pass levels. | Nils Hölscher | 2019-08-12 | 1 | -1/+2 |
| | | | | | I observed all Modules loading in the last fdt pass. The reason was, nexus bus loading with BUS_PASS_DEFAULT. | ||||
* | am335x display drivers: Port to RTEMS | Vijay Kumar Banerjee | 2019-08-11 | 2 | -0/+4 |
* | fbd: Port to RTEMS | Vijay Kumar Banerjee | 2019-08-11 | 9 | -0/+99 |
* | TDA19988: Port to RTEMS | Vijay Kumar Banerjee | 2019-08-11 | 7 | -0/+304 |
* | Pinmux: Port to RTEMS | Vijay Kumar Banerjee | 2019-08-11 | 4 | -0/+77 |
* | Add mmap | Vijay Kumar Banerjee | 2019-07-27 | 2 | -0/+40 |
* | EPOCH(9): Add epoch_drain_callbacks() | Sebastian Huber | 2019-07-09 | 2 | -2/+88 |
* | EPOCH(9): Avoid inline functions | Sebastian Huber | 2019-07-09 | 2 | -27/+35 |
| | | | | | FreeBSD changed the epoch_enter() and epoch_exit() inline functions into proper functions after a performance analysis to avoid code bloat. | ||||
* | SLEEPQUEUE(9): Fix timeout handling | Sebastian Huber | 2019-07-05 | 2 | -0/+4 |
* | i2c tool : port to RTEMS | Vijay Kumar Banerjee | 2019-06-29 | 3 | -0/+39 |
* | Add rtems i2c adaptation layer | Vijay Kumar Banerjee | 2019-06-29 | 1 | -0/+231 |
* | iicbus: port to RTEMS | Vijay Kumar Banerjee | 2019-06-29 | 4 | -0/+275 |
