* | debugger: Set the fd to -1 to indicate being disconnected. | Chris Johns | 2016-11-29 | 1 | -0/+1 |
* | Add a RTEMS Debugger TCP remote transport. | Chris Johns | 2016-11-29 | 2 | -0/+389 |
| | | | | | | | The patch also adds support to libbsd's build system making source conditional on a configure check. The debugger support is not available on all architectures and this feature lets us test if is avaliable. | ||||
* | ftpd: Use floating-point tasks due to syslog() | Sebastian Huber | 2016-11-24 | 1 | -4/+2 |
* | rtems-bsd-mutex: Update due to API changes | Sebastian Huber | 2016-11-24 | 1 | -5/+7 |
* | Fix errno redefined warning | Sebastian Huber | 2016-11-14 | 1 | -0/+2 |
* | Revert "rtems-kernel-page: Panic on recursive reclaim" | Sebastian Huber | 2016-11-14 | 1 | -31/+20 |
| | | | | | | This attempt to fix a memory allocation problem turned out to be broken. This reverts commit 651710509430eee6731807801bd5ad85d28f4db4. | ||||
* | rtems-kernel-page: Panic on recursive reclaim | Sebastian Huber | 2016-11-10 | 1 | -20/+31 |
* | Provide O_CLOEXEC | Sebastian Huber | 2016-11-09 | 1 | -0/+2 |
* | Provide CLOCK_UPTIME | Sebastian Huber | 2016-11-09 | 1 | -0/+4 |
* | Add thread fences to <machine/atomic.h> | Sebastian Huber | 2016-11-09 | 1 | -0/+52 |
* | Modify rtems_bsd_set_vprintf_handler() | Sebastian Huber | 2016-11-09 | 2 | -7/+18 |
| | | | | Return previous vprintf()-handler in rtems_bsd_set_vprintf_handler(). | ||||
* | Add empty <machine/_kernel_lock.h> | Sebastian Huber | 2016-11-09 | 1 | -0/+0 |
* | rtems-bsd-mutex: Optimize | Sebastian Huber | 2016-11-09 | 1 | -11/+52 |
| | | | | Inline SMP lock acquire/release. Avoid stack frame for hot path. | ||||
* | rtems-bsd-mutex: Update due to API changes | Sebastian Huber | 2016-11-03 | 1 | -3/+3 |
* | devfs: Fix includes | Sebastian Huber | 2016-10-26 | 1 | -5/+8 |
* | rtemsbsd: Add reallocf to rtems_bsd_program. | Christian Mauderer | 2016-10-24 | 2 | -0/+17 |
* | Add SIZE_T_MAX to <machine/rtems-bsd-user-space.h> | Sebastian Huber | 2016-10-24 | 1 | -0/+2 |
* | Provide CLOCK_MONOTONIC_FAST | Sebastian Huber | 2016-10-24 | 1 | -0/+4 |
* | Make <machine/atomic.h> available to user space | Sebastian Huber | 2016-10-24 | 1 | -4/+0 |
| | | | | Enables use of <sys/refcount.h> in user space. | ||||
* | nexus-devices: Support arm/lpc24xx | Sebastian Huber | 2016-10-07 | 1 | -0/+7 |
* | ohci: Fixes due to USB stack update | Sebastian Huber | 2016-10-07 | 1 | -21/+7 |
* | nexus-devices: Add arm/atsamv BSP section | Sebastian Huber | 2016-09-28 | 1 | -0/+5 |
* | Split rtemsbsd/rtems/rtems-program.c | Sebastian Huber | 2016-09-28 | 2 | -33/+79 |
| | | | | This improves garbage collection by the linker. | ||||
* | Split rtems-bsd-kernel-program.c | Sebastian Huber | 2016-09-28 | 3 | -645/+733 |
| | | | | Separate kernel and user space parts. | ||||
* | Split rtems-bsd-shell-netcmds.c | Sebastian Huber | 2016-09-28 | 8 | -74/+160 |
* | if_ffec_mcf548x.c: Fix include order | Sebastian Huber | 2016-09-23 | 1 | -2/+2 |
* | rtems-bsd-mutex: Update due to API changes | Sebastian Huber | 2016-09-22 | 1 | -25/+11 |
* | Use _Thread_Get_priority() | Sebastian Huber | 2016-09-22 | 1 | -1/+2 |
* | usb: Update to FreeBSD trunk 2016-08-23 | Sebastian Huber | 2016-08-23 | 2 | -2/+82 |
| | | | | FreeBSD trunk, 2016-08-23, 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | mmc: Update to FreeBSD trunk 2016-08-23 | Sebastian Huber | 2016-08-23 | 1 | -0/+0 |
* | devfs: Create path. | Christian Mauderer | 2016-08-16 | 1 | -2/+33 |
* | rc.conf/net: Let interface option appear on a DHCP ifconfig_ line. | Chris Johns | 2016-08-12 | 1 | -14/+28 |
| | | | | | | An ifconfig_ line can have other options for the interface such as ether or hardware checksum control. Allow these to be set on the interface. | ||||
* | nfsclient: Only parse for options when present. | Chris Johns | 2016-08-12 | 1 | -1/+4 |
* | rtems-bsd-mutex: Use _Thread_queue_Surrender() | Sebastian Huber | 2016-08-11 | 2 | -38/+8 |
* | pf: Add configuration via rc.conf. | Christian Mauderer | 2016-08-08 | 3 | -0/+266 |
* | rc.conf: Use more stack for the rc worker. | Christian Mauderer | 2016-08-08 | 1 | -1/+1 |
| | | | | | Most of the tests run with a default stack size of 32k. If the rc worker runs with less, it uses an untested configuration. | ||||
* | pf: Add RTEMS_BSD_CONFIG_FIREWALL_xxx options. | Christian Mauderer | 2016-08-08 | 1 | -0/+28 |
* | if_ffec_mcf548x: Init when interface is set to UP. | Christian Mauderer | 2016-08-05 | 1 | -0/+8 |
| | | | | Call the driver initialization function if the interface is set to UP. | ||||
* | freebsd: Add constant ipv6 addresses from vars.c. | Christian Mauderer | 2016-08-04 | 1 | -3/+0 |
| | | | | This is necessary for a configuration without IPv6. | ||||
* | pfctl: Add rtems_bsd_command_pfctl. | Christian Mauderer | 2016-08-02 | 3 | -0/+13 |
* | rtemsbsd: Add wrapper for open, fopen, malloc, ... | Christian Mauderer | 2016-08-02 | 2 | -2/+581 |
| | | | | | | | | | | | | | | | | | Add the following rtems_bsd_program_... wrapper: * rtems_bsd_program_open * rtems_bsd_program_socket * rtems_bsd_program_close * rtems_bsd_program_fopen * rtems_bsd_program_fclose * rtems_bsd_program_malloc * rtems_bsd_program_calloc * rtems_bsd_program_realloc * rtems_bsd_program_free * rtems_bsd_program_strdup * rtems_bsd_program_vasprintf * rtems_bsd_program_asprintf | ||||
* | rtemsbsd: Add call to program with a data restore | Christian Mauderer | 2016-08-02 | 2 | -0/+28 |
| | | | | This adds the rtems_bsd_program_call_main_width_data_restore function. | ||||
* | testsuite/pf01: Add test that links PF. | Christian Mauderer | 2016-08-01 | 1 | -0/+9 |
* | kern_conf.c: Adapt for RTEMS. | Christian Mauderer | 2016-08-01 | 1 | -65/+0 |
* | rtemsbsd/devfs: Add. | Christian Mauderer | 2016-08-01 | 1 | -0/+293 |
* | rtems-bsd-mutex: Update due to API changes | Sebastian Huber | 2016-07-28 | 3 | -23/+20 |
* | rtems-bsd-mutex: Update due to API changes | Sebastian Huber | 2016-07-27 | 1 | -2/+2 |
* | config: Fix telnetd configuration warning. | Chris Johns | 2016-07-19 | 1 | -3/+4 |
* | Make the license message viewable with a verbose option. | Chris Johns | 2016-07-06 | 3 | -16/+21 |
| | | | | | | The license details can be viewed if you mount with a -v option: # mount -i nfs -o "-v" 1.2.3.4:/mnt /mnt | ||||
* | Provide empty RTEMS_BSD_CFGDECL_.* defines if not used. | Chris Johns | 2016-07-01 | 1 | -0/+11 |
