* | Update to FreeBSD stable/12 2020-02-10 | Sebastian Huber | 2020-02-18 | 4 | -5/+154 |
| | | | | Git mirror commit 0d1c391321b34b3025cf0e72f2231d836ff76da8. | ||||
* | NVMECONTROL(8): Port to RTEMS | Sebastian Huber | 2019-11-13 | 3 | -0/+39 |
| | | | | Update #3821. | ||||
* | NVD(4): Add RTEMS-specific NVMe disk driver | Sebastian Huber | 2019-11-13 | 1 | -0/+341 |
* | NVME(4): Port to RTEMS | Sebastian Huber | 2019-11-13 | 1 | -0/+0 |
* | Add support for EARLY_COUNTER | Sebastian Huber | 2019-09-25 | 1 | -0/+10 |
* | Remove obsolete header files | Sebastian Huber | 2019-09-25 | 1 | -1/+0 |
* | Fix pgsigio() warnings | Sebastian Huber | 2019-09-25 | 2 | -51/+0 |
* | Add compatiblity for older Newlib variants | Sebastian Huber | 2019-09-25 | 1 | -0/+36 |
* | Update to FreeBSD stable/12 2019-09-23 | Sebastian Huber | 2019-09-23 | 3 | -12/+104 |
| | | | | Git mirror commit 7e8d1444023128d34fb9aa4e4515928a4f794d1b. | ||||
* | nexus: Avoid NULL pointer access | Sebastian Huber | 2019-09-23 | 1 | -1/+4 |
* | C++ compatiblity for kernel space header | Sebastian Huber | 2019-09-23 | 1 | -0/+8 |
* | Add wrapper for strndup() | Sebastian Huber | 2019-09-11 | 3 | -9/+31 |
* | atomic.h: Add atomic_load_long() | Sebastian Huber | 2019-08-27 | 1 | -0/+21 |
* | Update to FreeBSD stable/12 2019-08-26 | Sebastian Huber | 2019-08-26 | 1 | -2/+4 |
| | | | | Git mirror commit 621e7bafbf6857451f23ba11b0495c7ac69aff89. | ||||
* | rtems/rtems-kernel-nexus.c: LibBSD init now uses all pass levels. | Nils Hölscher | 2019-08-12 | 1 | -1/+2 |
| | | | | | I observed all Modules loading in the last fdt pass. The reason was, nexus bus loading with BUS_PASS_DEFAULT. | ||||
* | Update to FreeBSD stable/12 2019-07-09 | Sebastian Huber | 2019-07-09 | 1 | -0/+11 |
| | | | | Git mirror commit 3427c3416aa3c0f25124070959cca78024b94d85. | ||||
* | EPOCH(9): Add epoch_drain_callbacks() | Sebastian Huber | 2019-07-09 | 2 | -2/+88 |
* | EPOCH(9): Avoid inline functions | Sebastian Huber | 2019-07-09 | 2 | -27/+35 |
| | | | | | FreeBSD changed the epoch_enter() and epoch_exit() inline functions into proper functions after a performance analysis to avoid code bloat. | ||||
* | SLEEPQUEUE(9): Fix timeout handling | Sebastian Huber | 2019-07-05 | 2 | -0/+4 |
* | Update to FreeBSD stable/12 2019-06-26 | Sebastian Huber | 2019-06-26 | 2 | -0/+7 |
| | | | | Git mirror commit aa83598855d14cdbf7aef6b05d0617e90f87ca2f. | ||||
* | if_atsam: Remove WDT_Disable() | Sebastian Huber | 2019-06-13 | 1 | -3/+0 |
| | | | | | The watchdog timer (WDT) can be configure only once. Do not touch it in the BSP since the application may want to use it. | ||||
* | Update to FreeBSD stable/12 2019-06-05 | Sebastian Huber | 2019-06-05 | 5 | -3/+125 |
| | | | | Git mirror commit 78576620f2689e23144a1cf1bf55106cc6abe2b7. | ||||
* | Add RTEMS-specific getcredhostuuid() | Sebastian Huber | 2019-06-05 | 2 | -11/+29 |
* | Use _SMP_Unicast_action() | Sebastian Huber | 2019-05-21 | 2 | -8/+2 |
| | | | | It is a bit more efficient. | ||||
* | Update due to API changes | Sebastian Huber | 2019-05-15 | 1 | -5/+3 |
| | | | | Close #3749. | ||||
* | Separate libbsd and RTEMS clock ticks | Sebastian Huber | 2019-05-15 | 3 | -12/+11 |
* | Include missing <stdlib.h> to fix warnings | Sebastian Huber | 2019-05-15 | 1 | -0/+1 |
* | Remove unused maxusers | Sebastian Huber | 2019-05-15 | 2 | -3/+0 |
* | Remove jail/prison functions from namespace | Sebastian Huber | 2019-05-15 | 1 | -21/+0 |
* | Remove dangerous weak definition of getentropy() | Sebastian Huber | 2019-05-15 | 1 | -12/+0 |
| | | | | All BSP supporting libbsd should provide this function. | ||||
* | usb: Undefine USB_DEBUG | Sebastian Huber | 2019-05-13 | 1 | -1/+1 |
| | | | | | | In contrast to some other USB options which use 0/1 values, the USB_DEBUG uses defined/undefined to enable/disable the USB debug support. | ||||
* | Add wrapper for abort() | Sebastian Huber | 2019-05-13 | 1 | -2/+7 |
* | Add USB mass storage only build set | Sebastian Huber | 2019-05-13 | 1 | -0/+4 |
* | Use static inline functions for jail and prison | Sebastian Huber | 2019-05-13 | 1 | -230/+0 |
| | | | | This helps the compiler to optimize away dead code. | ||||
* | Fix zero-copy mbuf support | Sebastian Huber | 2019-05-13 | 2 | -4/+2 |
| | | | | In 2017 there was a change in the mbuf API. | ||||
* | Update due to API changes | Sebastian Huber | 2019-04-11 | 5 | -9/+9 |
* | nfsclient: Fix for 64-bit targets | Sebastian Huber | 2019-03-29 | 1 | -1/+8 |
| | | | | | | | The use of the serporid structure with several embedded unions to split up the specific NFS request/response structures is quite a hack. It breaks on 64-bit targets due to the presence of pointer members which affect the overall alignment. | ||||
* | Revert "Add BURN_BRIDGES global kernel option" | Sebastian Huber | 2019-03-29 | 1 | -5/+0 |
| | | | | This reverts commit b5cc3f67ed15f23a868c7f846dca48ff9f3f803a. | ||||
* | Add BURN_BRIDGES global kernel option | Sebastian Huber | 2019-03-28 | 1 | -0/+5 |
* | Update to FreeBSD stable/12 2019-03-27 | Sebastian Huber | 2019-03-28 | 3 | -0/+30 |
| | | | | Git mirror commit 43a38f188ca2e936ec78104c30ea3e24d9c1606b. | ||||
* | bin/openssl: Port to RTEMS. | Christian Mauderer | 2019-03-28 | 3 | -0/+43 |
* | Update to FreeBSD stable/12 2019-03-11 | Sebastian Huber | 2019-03-11 | 3 | -3/+12 |
| | | | | Git mirror commit 735fe7a0a5f9c265040e2e6654a01b081d6354f1. | ||||
* | Remove unused file | Sebastian Huber | 2019-03-11 | 1 | -224/+0 |
* | Build C++ kernel-space compatibility file | Sebastian Huber | 2019-02-18 | 1 | -2/+3 |
* | Fix atomic_load_32() | Sebastian Huber | 2019-02-18 | 1 | -1/+1 |
* | Remove <linux/rbtree.h> | Sebastian Huber | 2019-02-12 | 1 | -146/+0 |
| | | | | It is already provided by RTEMS. | ||||
* | Remove obsolete <rtems/pty.h> | Sebastian Huber | 2019-02-12 | 1 | -68/+0 |
* | mghttpd: Remove | Sebastian Huber | 2019-02-12 | 2 | -5907/+0 |
| | | | | The mghttpd is already provided by RTEMS. | ||||
* | ZONE(9): Fix UMA_PCPU_ALLOC_SIZE | Sebastian Huber | 2019-02-12 | 1 | -2/+2 |
| | | | | | Using CACHE_LINE_SIZE for UMA_PCPU_ALLOC_SIZE was a huge memory waste since the backend memory allocator is page based. | ||||
* | Update to FreeBSD stable/12 2019-02-11 | Sebastian Huber | 2019-02-12 | 12 | -99/+496 |
| | | | | Git mirror commit 606b591dae1023a71ff020faf99789059eb6591f. |
