* | vprintf: Add handler that mutes all output. | Christian Mauderer | 2018-03-23 | 1 | -0/+10 |
| | | | | | This adds a vprintf handler that can be used to suppress all outputs of the libbsd. | ||||
* | Silence rtems_bsd_ifconfig() | Sebastian Huber | 2018-03-23 | 1 | -0/+1 |
* | mutex: Use panic() after ISR lock release | Sebastian Huber | 2018-03-13 | 1 | -3/+7 |
| | | | | | | Using panic() with interrupts disabled could lead to an additional error (INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT) due to a potentially blocking output. | ||||
* | termios: Update due to API changes | Sebastian Huber | 2018-02-05 | 1 | -23/+8 |
| | | | | Update #2843. | ||||
* | Add rtems_bsd_ifconfig() | Sebastian Huber | 2018-01-23 | 1 | -0/+75 |
* | Add rtems_bsd_initialize_dhcp() | Sebastian Huber | 2017-12-05 | 1 | -0/+115 |
* | Revert "RWLOCK(9): Add reader/writer lock implementation" | Sebastian Huber | 2017-11-17 | 2 | -260/+30 |
| | | | | | | This was accidentally committed. This reverts commit 97a98f6cd767b3a68279890488c7b451788f84f4. | ||||
* | Revert "SX(9): Implement with reader/writer lock" | Sebastian Huber | 2017-11-17 | 1 | -93/+28 |
| | | | | | | This was accidentally committed. This reverts commit cc7a8d87e7307db738bf39ab1ca3ce1053f1c163. | ||||
* | SX(9): Implement with reader/writer lock | Sebastian Huber | 2017-11-16 | 1 | -28/+93 |
* | RWLOCK(9): Add reader/writer lock implementation | Sebastian Huber | 2017-11-16 | 2 | -30/+260 |
* | LOCKING(9): Remove dead code (DDB) | Sebastian Huber | 2017-11-16 | 3 | -12/+0 |
* | LOCKING(9): Remove dead code (KDTRACE_HOOKS) | Sebastian Huber | 2017-11-16 | 3 | -59/+0 |
* | LOCKING(9): Update to current FreeBSD version | Sebastian Huber | 2017-11-16 | 3 | -58/+64 |
* | wpa_supplicant: Add lock. | Christian Mauderer | 2017-11-10 | 1 | -0/+68 |
* | wpa_supplicant: Move forking command into own file. | Christian Mauderer | 2017-11-10 | 1 | -0/+64 |
| | | | | | The malloc wrapper must not be disabled. Therefore the command that uses malloc without a wrapper has to live in another file. | ||||
* | Add wpa_supplicant_fork command. | Sichen Zhao | 2017-11-10 | 1 | -0/+36 |
| | | | | Add fork command for wpa supplicant to start a new task. | ||||
* | Port wpa supplicant to RTEMS. | Sichen Zhao | 2017-11-10 | 2 | -0/+83 |
| | | | | Add wpa_supplicant lib support and shell command support in RTEMS. | ||||
* | Add rtems_bsd_ifconfig_lo0() | Sebastian Huber | 2017-11-10 | 1 | -0/+77 |
* | rtems-bsd-mutex: Update due to API changes | Sebastian Huber | 2017-10-24 | 1 | -2/+1 |
| | | | | Update #3117. | ||||
* | Add rtems_bsd_set_if_input() | Sebastian Huber | 2017-10-23 | 1 | -0/+71 |
* | Initialize BSD user extension earlier | Sebastian Huber | 2017-10-20 | 1 | -1/+1 |
* | Fix INVARIANTS support | Sebastian Huber | 2017-10-20 | 3 | -193/+105 |
* | rtems-kernel-page: Reclaim pages earlier | Sebastian Huber | 2017-10-20 | 1 | -9/+13 |
* | rtems-kernel-page: Add used pages counter | Sebastian Huber | 2017-10-20 | 1 | -19/+25 |
* | Generalize bsp_fdt_map_intr() | Sebastian Huber | 2017-09-22 | 1 | -1/+1 |
| | | | | Update #3090. | ||||
* | Support reference counting for file descriptors | Sebastian Huber | 2017-09-15 | 1 | -1/+6 |
| | | | | Close #3132. | ||||
* | Include missing <string.h> and <limits.h> | Sebastian Huber | 2017-08-25 | 1 | -0/+2 |
| | | | | | | | Fix warnings. Update #2132. Update #2133. | ||||
* | Enable the WEP encrypted WiFi. | Sichen Zhao | 2017-08-02 | 1 | -0/+2 |
| | | | | Now rtems can connnect WiFi via WEP on rtl8188eu chip. | ||||
* | termios: Interrupt server API changes | Sebastian Huber | 2017-07-12 | 1 | -3/+3 |
* | Use LOG_EMERG for panic() | Sebastian Huber | 2017-07-10 | 1 | -6/+3 |
* | Use <sys/lock.h> provided by Newlib | Sebastian Huber | 2017-06-08 | 10 | -11/+11 |
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 21 | -22/+22 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Add keyboard driver set variable | Kevin Kirspel | 2017-05-19 | 1 | -0/+4 |
* | Adding RTEMS support for FREEBSD TTY | Kevin Kirspel | 2017-05-11 | 1 | -0/+40 |
* | rc_conf: Move the defaultroute_delay to the defaultroute processing. | Chris Johns | 2017-04-27 | 1 | -49/+60 |
| | | | | | If no default route is found atfer the delay timeout set the defaultrouter value if present. | ||||
* | rc_conf: Add support for ifconfig_<interface>_alias[0-9]+. | Chris Johns | 2017-04-27 | 1 | -13/+68 |
| | | | | | | | | | | The interface alias allows extra IP addresses to be set on and interface and it also allows the MAC address to be set. Examples: ifconfig_em0="inet 10.10.5.33 netmask 255.255.255.0" ifconfig_em0_alias0="ether 10:22:33:44:55:66" ifconfig_em0_alias1="inet 10.1.1.111 netmask 0xffffffff" | ||||
* | rc_conf: Do not use a local variable for the rc_conf context. | Chris Johns | 2017-04-26 | 1 | -41/+51 |
| | | | | | | If a network error occurs or there is no waiter on rc_conf processing the worker thread is left holding a local stack struct ater the call has returned. Allocate on the heap. | ||||
* | rc_conf: Minor clean up in the net services. | Chris Johns | 2017-04-26 | 1 | -2/+3 |
* | FDT(4): Port to RTEMS | Sebastian Huber | 2017-03-08 | 2 | -3/+93 |
* | Add poll() and select() support for Termios | Sebastian Huber | 2017-02-28 | 1 | -0/+283 |
* | freebsd/wlanstats: Port to FreeBSD. | Christian Mauderer | 2017-01-17 | 1 | -0/+42 |
* | lib80211/regdomain: Port to RTEMS. | Christian Mauderer | 2017-01-17 | 1 | -0/+4484 |
* | wlan ratectl and sta: Call init. | Christian Mauderer | 2017-01-17 | 1 | -1/+5 |
* | Port IEEE 802.11. | Christian Mauderer | 2017-01-17 | 1 | -0/+4 |
* | Use thread name support | Sebastian Huber | 2017-01-13 | 2 | -119/+2 |
| | | | | Update #2858. | ||||
* | rtems-bsd-mutex: Update due to API changes | Sebastian Huber | 2017-01-11 | 1 | -1/+1 |
* | ARP(8): Port to RTEMS | Sebastian Huber | 2017-01-10 | 1 | -0/+40 |
* | VMSTAT(8): Port to RTEMS | Sebastian Huber | 2017-01-10 | 1 | -0/+40 |
* | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 2017-01-10 | 10 | -60/+101 |
| | | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | rtems-bsd-mutex: Update due to API changes | Sebastian Huber | 2016-11-24 | 1 | -5/+7 |
