Ths syslog priority is a mask not a level.
priority.
The rc.conf has 'syslog_priority' where the priority is the name, eg
syslog_priority="debug"
sets the priority to "debug".
Avoid potential buffer overflows on the stack. Expand the %m in the
format string.
Add compatibility with Newlib header files. Some FreeBSD header files
are mapped by the translation script:
o rtems/bsd/sys/_types.h
o rtems/bsd/sys/errno.h
o rtems/bsd/sys/lock.h
o rtems/bsd/sys/param.h
o rtems/bsd/sys/resource.h
o rtems/bsd/sys/time.h
o rtems/bsd/sys/timespec.h
o rtems/bsd/sys/types.h
o rtems/bsd/sys/unistd.h
It is now possible to include <sys/socket.h> directly for example.
Generate one Makefile which builds everything including tests.
This was covering up rtems-bsd-config.h.in undefining __P. These
files can remain closer to the FreeBSD originals.
