2017-06-08 | Use <sys/lock.h> provided by Newlib | Sebastian Huber | 1 | -1/+1 | |
2016-09-28 | Split rtems-bsd-kernel-program.c | Sebastian Huber | 1 | -645/+19 | |
Separate kernel and user space parts. | |||||
2016-08-02 | rtemsbsd: Add wrapper for open, fopen, malloc, ... | Christian Mauderer | 1 | -1/+490 | |
Add the following rtems_bsd_program_... wrapper: * rtems_bsd_program_open * rtems_bsd_program_socket * rtems_bsd_program_close * rtems_bsd_program_fopen * rtems_bsd_program_fclose * rtems_bsd_program_malloc * rtems_bsd_program_calloc * rtems_bsd_program_realloc * rtems_bsd_program_free * rtems_bsd_program_strdup * rtems_bsd_program_vasprintf * rtems_bsd_program_asprintf | |||||
2016-08-02 | rtemsbsd: Add call to program with a data restore | Christian Mauderer | 1 | -0/+23 | |
This adds the rtems_bsd_program_call_main_width_data_restore function. | |||||
2016-06-23 | Update due to RTEMS printer API changes | Sebastian Huber | 1 | -0/+1 | |
2016-05-30 | Directly use <sys/types.h> provided by Newlib | Sebastian Huber | 1 | -1/+1 | |
2016-05-06 | Rename files for kernel namespace script | Sebastian Huber | 1 | -0/+0 | |
This makes it easier to create the kernel namespace header. | |||||
2015-06-19 | Remove #undefs and fix formatting. | Chris Johns | 1 | -6/+7 | |
2015-06-16 | Add error() to the BSD program support. | Chris Johns | 1 | -0/+13 | |
2013-11-11 | Rename rtems-bsd-config.h | Sebastian Huber | 1 | -1/+1 | |
Rename rtems-bsd-config.h in rtems-bsd-kernel-space.h. | |||||
2013-10-31 | Move program control to thread structure | Sebastian Huber | 1 | -0/+202 | |
