* | Use <sys/lock.h> provided by Newlib | Sebastian Huber | 2017-06-08 | 1 | -1/+1 |
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Rename files for kernel namespace script | Sebastian Huber | 2016-05-06 | 1 | -0/+504 |
This makes it easier to create the kernel namespace header. |
