2017-01-10 | VMSTAT(8): Port to RTEMS | Sebastian Huber | 1 | -4/+4 | |
2016-09-28 | Split rtems-bsd-shell-netcmds.c | Sebastian Huber | 1 | -5/+5 | |
This improves garbage collection by the linker. | |||||
2014-01-30 | DHCPCD(8): Add basic support | Sebastian Huber | 1 | -1/+9 | |
2013-10-10 | Update files to match FreeBSD layout | Sebastian Huber | 1 | -12/+9 | |
Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | |||||
2013-10-10 | Move files to match FreeBSD layout | Sebastian Huber | 1 | -0/+0 | |
2012-03-08 | Move rtems/freebsd to freebsd and contrib to freebsd/contrib | Joel Sherrill | 1 | -0/+0 | |
