The following files are now provided by Newlib:
* arpa/inet.h
* net/if.h
* netinet/in.h
* netinet/tcp.h
* sys/socket.h
* sys/uio.h
* sys/un.h
The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be
used directly.
Update #2833.
If no default route is found atfer the delay timeout set the
defaultrouter value if present.
The interface alias allows extra IP addresses to be set on and
interface and it also allows the MAC address to be set.
Examples:
ifconfig_em0="inet 10.10.5.33 netmask 255.255.255.0"
ifconfig_em0_alias0="ether 10:22:33:44:55:66"
ifconfig_em0_alias1="inet 10.1.1.111 netmask 0xffffffff"
An ifconfig_ line can have other options for the interface such as
ether or hardware checksum control. Allow these to be set on the
interface.
Provide user support for rc.conf(5) so a user can create a suitable
/etc/rc.conf file to initialise libbsd.
This patch by default adds basic networking support:
cloned_interfaces
ifconfig_'interface'
defaultrouter
hostname
Refer to FreeBSD documentation for examples.
Users can make a single call to have /etc/rc.conf processed, or pass a
file name to a specific configuration file or a text string with line
feeds can be passed to the scripting version of the interface.
The rc.conf support is implemented in terms of directive handlers that
are called based on a regular expression. The design allows new handlers
to be added as needed.
Line concatenation is still to be implemented.
