* | Make the domain allocation size global to allow it to set in tests. | Chris Johns | 2016-06-27 | 1 | -1/+3 |
| | | | | | | Some BSPs with multiple NIC locked in the tests due to not enough memory. This provides a simple per BSP way to increase the memory size. | ||||
* | Add and use rtems_bsd_get_allocator_domain_size() | Sebastian Huber | 2015-02-13 | 1 | -0/+58 |
