2016-09-28 | Split rtems-bsd-kernel-program.c | Sebastian Huber | 1 | -20/+31 | |
Separate kernel and user space parts. | |||||
2016-06-23 | Update due to RTEMS printer API changes | Sebastian Huber | 1 | -0/+2 | |
2016-05-30 | Directly use <sys/types.h> provided by Newlib | Sebastian Huber | 1 | -1/+1 | |
2016-05-06 | Rename files for kernel namespace script | Sebastian Huber | 1 | -0/+0 | |
This makes it easier to create the kernel namespace header. | |||||
2014-09-25 | Delete rtems_bsd_thread_chain | Sebastian Huber | 1 | -27/+2 | |
Rely on RTEMS object registration for threads. | |||||
2013-11-11 | Rename rtems-bsd-config.h | Sebastian Huber | 1 | -1/+1 | |
Rename rtems-bsd-config.h in rtems-bsd-kernel-space.h. | |||||
2013-10-10 | Use extension to attach a struct thread to threads | Sebastian Huber | 1 | -8/+10 | |
Add test thread01. | |||||
2013-10-10 | Update files to match FreeBSD layout | Sebastian Huber | 1 | -8/+8 | |
Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | |||||
2013-10-10 | Move files to match FreeBSD layout | Sebastian Huber | 1 | -0/+0 | |
2012-05-08 | Modified copyright on rtems-bsd-xxx files to be consistant with FreeBSD ↵ | Jennifer Averett | 1 | -3/+20 | |
copyright. | |||||
2012-03-08 | Remove rtems/ from includes of RTEMS specific files | Joel Sherrill | 1 | -8/+8 | |
2012-03-07 | Separate RTEMS Specific Files from Those Direct from FreeBSD | Joel Sherrill | 1 | -0/+0 | |
