Changes correspond to FreeBSD commit:
"Make timespecadd(3) and friends public
The timespecadd(3) family of macros were imported from NetBSD back in
r35029. However, they were initially guarded by #ifdef _KERNEL. In the
meantime, we have grown at least 28 syscalls that use timespecs in some
way, leading many programs both inside and outside of the base system to
redefine those macros. It's better just to make the definitions public.
Our kernel currently defines two-argument versions of timespecadd and
timespecsub. NetBSD, OpenBSD, and FreeDesktop.org's libbsd, however, define
three-argument versions. Solaris also defines a three-argument version, but
only in its kernel. This revision changes our definition to match the
common three-argument version.
Bump _FreeBSD_version due to the breaking KPI change.
Discussed with: cem, jilles, ian, bde
Differential Revision: https://reviews.freebsd.org/D14725"
Update #3472.
Update #3277.
Translate address in of_address_to_resource().
Update #3277.
Update #3277.
Update #3277.
Update #3277.
Update #3277.
Update #3277.
Update #3277.
Update #3277.
Update #3277.
By default, the network interfaces use a pool channel, see
dpaa_get_channel() in dpaa_eth_priv_probe(). To enable a dedicated QMan
software portal, use libbsd,dedicated-portal = "enabled";. This option
is useful for special purpose 10Gbit/s Ethernet processing.
soc: soc@ffe000000 {
fman0: fman@400000 {
enet7: ethernet@f2000 {
Linux baseline a71c9a1c779f2499fb2afc0553e543f18aff6edf (4.11-rc5).
Imported from Freescale Linux repository
git://git.freescale.com/ppc/upstream/linux.git
commit 2774c204cd8bfc56a200ff4dcdfc9cdf5b6fc161.
Linux compatibility layer is partly from FreeBSD.
