path: root/rtemsbsd/local/pci_if.c (follow)
* Update to FreeBSD head 2018-04-01Sebastian Huber2018-09-211-0/+12
| | | | | | Git mirror commit 8dfb1ccc26d1cea7e2529303003ff61f9f1784c4. Update #3472.
* Update to FreeBSD head 2016-08-23Sebastian Huber2017-01-101-77/+72
| | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd.
* Rename rtems-bsd-config.hSebastian Huber2013-11-111-1/+1
| | | | Rename rtems-bsd-config.h in rtems-bsd-kernel-space.h.
* Update to FreeBSD 8.4Sebastian Huber2013-11-041-1/+1
* Update files to match FreeBSD layoutSebastian Huber2013-10-101-7/+7
| | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests.
* Move files to match FreeBSD layoutSebastian Huber2013-10-101-0/+172
