* | rtems_bsd_mutex: SMP support via ISR locks | Sebastian Huber | 2015-03-06 | 2 | -21/+28 |
* | atomic.h: Use <stdatomic.h> or <atomic> for SMP | Sebastian Huber | 2015-03-06 | 1 | -34/+1041 |
* | atomic.h: Format changes | Sebastian Huber | 2015-03-06 | 1 | -21/+33 |
* | Change license to BSD | Sebastian Huber | 2015-03-06 | 6 | -26/+128 |
* | Mark header files as empty | Sebastian Huber | 2015-03-06 | 2 | -65/+2 |
* | Delete unused files | Sebastian Huber | 2015-03-06 | 3 | -146/+0 |
* | Add zerocopy sendto | Sebastian Huber | 2015-02-13 | 1 | -0/+68 |
* | Update to FreeBSD 9.3 | Sebastian Huber | 2015-02-13 | 4 | -20/+1476 |
* | if_tsec: Add Nexus support | Sebastian Huber | 2015-02-13 | 1 | -1/+28 |
* | Add and use rtems_bsd_get_allocator_domain_size() | Sebastian Huber | 2015-02-13 | 1 | -0/+20 |
* | Add a simple page allocator | Sebastian Huber | 2015-01-29 | 1 | -0/+92 |
* | Add Xilinx Zynq BSP support | Sebastian Huber | 2015-01-21 | 2 | -0/+35 |
* | Add rtems_bsd_get_mac_address() | Sebastian Huber | 2015-01-21 | 1 | -0/+20 |
* | Add and use rtems_bsd_get_task_stack_size() | Sebastian Huber | 2015-01-20 | 2 | -3/+13 |
* | Add and use rtems_bsd_get_task_priority() | Sebastian Huber | 2015-01-20 | 2 | -9/+14 |
* | Add rtems_mdns_gethostname() | Sebastian Huber | 2014-11-10 | 1 | -3/+24 |
* | Fix spelling | Sebastian Huber | 2014-11-06 | 1 | -2/+2 |
* | Add rtems_mdns_sethostname() | Sebastian Huber | 2014-11-06 | 1 | -0/+17 |
| | | | | | Use it to set the multi-cast hostname of the default mDNS resolver instance via sethostname(). | ||||
* | HOSTNAME(1): Import from FreeBSD | Sebastian Huber | 2014-11-05 | 1 | -1/+2 |
* | Add mDNS support for name service dispatcher | Sebastian Huber | 2014-11-04 | 1 | -0/+74 |
* | Add rtems_bsd_force_select_timeout() | Sebastian Huber | 2014-11-04 | 1 | -0/+19 |
* | nexus-devices: Only register fec0 | Sebastian Huber | 2014-10-31 | 1 | -2/+0 |
| | | | | This makes testing of IPv4LL a bit easier. | ||||
* | ppp: Port to new stack | Sebastian Huber | 2014-10-08 | 1 | -0/+0 |
* | ppp: Import from RTEMS sources | Sebastian Huber | 2014-10-08 | 3 | -0/+83 |
* | nexus: Use a linker set for the devices | Sebastian Huber | 2014-10-08 | 2 | -5/+73 |
* | Delete obsolete _bsd_nexus_devices | Sebastian Huber | 2014-10-08 | 1 | -3/+0 |
* | Delete rtems_bsd_thread_chain | Sebastian Huber | 2014-09-25 | 3 | -16/+19 |
| | | | | Rely on RTEMS object registration for threads. | ||||
* | BSD_ASSERT(): Optimize | Sebastian Huber | 2014-09-24 | 1 | -1/+1 |
* | rtems_bsd_mutex: Optimize | Sebastian Huber | 2014-09-24 | 1 | -50/+23 |
* | Replace RTEMS objects with custom implementation | Sebastian Huber | 2014-09-23 | 3 | -14/+280 |
| | | | | | | | | Performance analysis revealed that the standard RTEMS objects are a major bottleneck. The object get mechanism and attribute checks at runtime have a significant overhead. Use a custom implementation for synchronization primitives. This drops also the size of the synchronization primitives considerably. | ||||
* | Disable IPsec | Sebastian Huber | 2014-09-23 | 2 | -2/+0 |
| | | | | | IPsec has a significant performance impact. Disable it for now since is only partially supported and untested. | ||||
* | Import and use subr_lock.c | Sebastian Huber | 2014-09-22 | 1 | -0/+0 |
* | telnetd: Import from RTEMS sources | Sebastian Huber | 2014-09-18 | 2 | -0/+178 |
* | DHCPCD(8): Add basic support | Sebastian Huber | 2014-01-30 | 2 | -0/+3 |
* | Add and use RTEMS_BSD_ARGC() | Sebastian Huber | 2014-01-30 | 1 | -1/+3 |
* | Add an ARP packet processor | Sebastian Huber | 2014-01-30 | 1 | -0/+20 |
* | Add rtems_bsd_get_ethernet_addr() | Sebastian Huber | 2014-01-30 | 1 | -0/+21 |
* | Add <rtems/bsd/util.h> | Sebastian Huber | 2014-01-30 | 1 | -0/+43 |
* | UNIX(4): Import from FreeBSD | Sebastian Huber | 2014-01-16 | 1 | -0/+3 |
* | Delete rtems_bsd_initialize_with_interrupt_server | Sebastian Huber | 2013-12-20 | 1 | -2/+0 |
| | | | | Move interrupt server initialization to nexus_probe(). | ||||
* | Use integer-only printf in kernel space | Sebastian Huber | 2013-12-20 | 2 | -0/+79 |
* | Always enable IPv6 | Sebastian Huber | 2013-12-20 | 1 | -0/+0 |
* | BPF(4): Add support | Sebastian Huber | 2013-12-16 | 1 | -0/+1 |
* | Add support for boottimebin and getbinuptime() | Sebastian Huber | 2013-12-16 | 1 | -0/+9 |
* | Move __FreeBSD__ define to header files | Sebastian Huber | 2013-12-16 | 2 | -0/+4 |
* | Move <sys/_cpuset.h> | Sebastian Huber | 2013-12-16 | 1 | -0/+60 |
* | Add RTEMS legacy MII support | Sebastian Huber | 2013-12-16 | 1 | -0/+139 |
* | Add support for M68K | Sebastian Huber | 2013-12-16 | 1 | -1/+1 |
* | ftpd01: New test | Sebastian Huber | 2013-12-16 | 1 | -0/+74 |
* | Changes due to <sys/cpuset.h> from latest Newlib | Sebastian Huber | 2013-12-04 | 1 | -0/+168 |
