* | TDA19988: Port to RTEMS | Vijay Kumar Banerjee | 2019-08-11 | 3 | -0/+163 |
* | Pinmux: Port to RTEMS | Vijay Kumar Banerjee | 2019-08-11 | 1 | -0/+40 |
* | i2c tool : port to RTEMS | Vijay Kumar Banerjee | 2019-06-29 | 1 | -0/+2 |
* | iicbus: port to RTEMS | Vijay Kumar Banerjee | 2019-06-29 | 1 | -0/+166 |
* | usb: Undefine USB_DEBUG | Sebastian Huber | 2019-05-13 | 1 | -1/+1 |
| | | | | | | In contrast to some other USB options which use 0/1 values, the USB_DEBUG uses defined/undefined to enable/disable the USB debug support. | ||||
* | Add USB mass storage only build set | Sebastian Huber | 2019-05-13 | 1 | -0/+4 |
* | Fix zero-copy mbuf support | Sebastian Huber | 2019-05-13 | 1 | -2/+1 |
| | | | | In 2017 there was a change in the mbuf API. | ||||
* | bin/openssl: Port to RTEMS. | Christian Mauderer | 2019-03-27 | 1 | -0/+1 |
* | Remove obsolete <rtems/pty.h> | Sebastian Huber | 2019-02-12 | 1 | -68/+0 |
* | Update to FreeBSD head 2018-12-20 | Sebastian Huber | 2018-12-20 | 3 | -30/+169 |
| | | | | | | | | | | Git mirror commit 19a6ceb89dbacf74697d493e48c388767126d418. It includes an update of wpa_supplicant to version 2.7. It includes an update of the OpenSSL baseline to version 1.1.1a. Update #3472. | ||||
* | freebsd/if_cpsw: Port. | Christian Mauderer | 2018-12-20 | 1 | -0/+0 |
* | Update to FreeBSD head 2018-10-23 | Sebastian Huber | 2018-10-25 | 2 | -0/+14 |
| | | | | | | | | | | | Git mirror commit 59f44d20be3f99d181ca742e636d45fc39ec982b. This commit updates OpenSSL to version 1.1.1. This required an update of racoon which uses some internal stuff from OpenSSL and seems to be mostly unmaintained, e.g. there is update in the FreeBSD ports to cope with OpenSSL 1.1.1. Update #3472. | ||||
* | Update gpio interface | Sebastian Huber | 2018-09-25 | 1 | -10/+65 |
| | | | | Update #3525. | ||||
* | Update to FreeBSD head 2018-09-17 | Sebastian Huber | 2018-09-21 | 4 | -63/+652 |
| | | | | | | Git mirror commit 6c2192b1ef8c50788c751f878552526800b1e319. Update #3472. | ||||
* | Update to FreeBSD head 2018-04-01 | Sebastian Huber | 2018-09-21 | 3 | -26/+147 |
| | | | | | | Git mirror commit 8dfb1ccc26d1cea7e2529303003ff61f9f1784c4. Update #3472. | ||||
* | Update to FreeBSD head 2018-02-01 | Sebastian Huber | 2018-09-21 | 4 | -39/+163 |
| | | | | | | Git mirror commit d079ae0442af8fa3cfd6d7ede190d04e64a2c0d4. Update #3472. | ||||
* | Update to FreeBSD head 2017-12-01 | Sebastian Huber | 2018-09-21 | 2 | -0/+42 |
| | | | | | | Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266. Update #3472. | ||||
* | Update to FreeBSD head 2017-10-01 | Sebastian Huber | 2018-09-21 | 3 | -20/+50 |
| | | | | | | Git mirror commit b2f0376b45428f13151d229c5ae9d4d8f74acbd1. Update #3472. | ||||
* | Update to FreeBSD head 2017-08-01 | Sebastian Huber | 2018-09-21 | 4 | -1/+53 |
| | | | | | | Git mirror commit f5002f5e5f78cae9f0269d812dc0aedb0339312c. Update #3472. | ||||
* | Update to FreeBSD head 2017-06-01 | Sebastian Huber | 2018-09-21 | 2 | -2/+4 |
| | | | | | | Git mirror commit dfb26efac4ce9101dda240e94d9ab53f80a9e131. Update #3472. | ||||
* | Add ipsec to rc.conf. | Christian Mauderer | 2018-08-02 | 1 | -0/+53 |
* | ipsec-tools: Port libipsec, setkey and racoon. | Christian Mauderer | 2018-08-02 | 1 | -0/+3 |
| | | | | | Note that this replaces the libipsec from FreeBSD with the one provided by ipsec-tools. | ||||
* | if_ipsec: Port and add to everything-buildset. | Christian Mauderer | 2018-08-01 | 1 | -0/+5 |
| | | | | | This ports the kernel space parts for ipsec and adds them to the everything-buildset. | ||||
* | dhcpcd: Add hooks | Sebastian Huber | 2018-05-08 | 1 | -0/+26 |
* | dhcpcd: Add rtems_dhcpcd_start() | Sebastian Huber | 2018-05-08 | 1 | -0/+84 |
| | | | | Use it throughout to start the DHCP client (dhcpcd). | ||||
* | buildset: Add minimal and everything config. | Christian Mauderer | 2018-05-03 | 1 | -1/+4 |
| | | | | | | | | | | | | This adds two new buildset configurations: One that leaves out as much features as possible and one that enables all features. For the default configuration WiFi support is now disabled. To disable IPv6 for the minimal configuration, all -DINET6 are eliminated in libbsd.py. They are now replaced by a #ifdef that checks for RTEMS_BSD_MODULE_NETINET6 instead. Close #3351. | ||||
* | rtems-debugger: Remove files | Sebastian Huber | 2018-05-02 | 1 | -47/+0 |
| | | | | | | They are now in the main RTEMS sources. Update #3419. | ||||
* | Use network services from RTEMS | Sebastian Huber | 2018-04-30 | 3 | -354/+0 |
| | | | | Close #3419. | ||||
* | vprintf: Add handler that mutes all output. | Christian Mauderer | 2018-03-23 | 1 | -0/+9 |
| | | | | | This adds a vprintf handler that can be used to suppress all outputs of the libbsd. | ||||
* | dpaa: QMan portal only initialization | Sebastian Huber | 2018-01-23 | 1 | -0/+4 |
| | | | | Update #3277. | ||||
* | dpaa: Add and use SDK_DPAA_COMPAT_STATIC | Sebastian Huber | 2018-01-23 | 1 | -0/+9 |
* | dpaa: Remove unused configuration defines | Sebastian Huber | 2018-01-23 | 1 | -9/+0 |
* | Add rtems_bsd_ifconfig() | Sebastian Huber | 2018-01-23 | 1 | -0/+16 |
* | Add rtems_bsd_initialize_dhcp() | Sebastian Huber | 2017-12-05 | 1 | -0/+22 |
* | at91_mci: Port to RTEMS and adapt for atsam. | Christian Mauderer | 2017-11-10 | 1 | -0/+0 |
* | Add wpa_supplicant_fork command. | Sichen Zhao | 2017-11-10 | 1 | -0/+2 |
| | | | | Add fork command for wpa supplicant to start a new task. | ||||
* | Port wpa supplicant to RTEMS. | Sichen Zhao | 2017-11-10 | 1 | -0/+2 |
| | | | | Add wpa_supplicant lib support and shell command support in RTEMS. | ||||
* | Port BBB sd driver files to RTEMS. | Sichen Zhao | 2017-11-10 | 2 | -0/+368 |
| | | | | So BBB can mount and read eMMC and SD card. | ||||
* | Add rtems_bsd_ifconfig_lo0() | Sebastian Huber | 2017-11-10 | 1 | -0/+7 |
* | Fix general PowerPC build | Sebastian Huber | 2017-10-26 | 1 | -0/+8 |
* | Add rtems_bsd_set_if_input() | Sebastian Huber | 2017-10-23 | 1 | -1/+24 |
* | Import DPAA driver snapshot | Sebastian Huber | 2017-10-23 | 1 | -0/+12 |
| | | | | | | | | | | Imported from Freescale Linux repository git://git.freescale.com/ppc/upstream/linux.git commit 2774c204cd8bfc56a200ff4dcdfc9cdf5b6fc161. Linux compatibility layer is partly from FreeBSD. | ||||
* | if_atsam: Allow fixed MII settings. | Christian Mauderer | 2017-09-22 | 1 | -0/+53 |
* | Port am335x usb driver to RTEMS. | Sichen Zhao | 2017-07-13 | 1 | -0/+0 |
| | | | | | | Add FDT and umass support for am335x USB driver. Now RTEMS can mount and open USB disk. | ||||
* | Use <sys/lock.h> provided by Newlib | Sebastian Huber | 2017-06-08 | 1 | -319/+0 |
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 3 | -705/+0 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Modify FREEBSD EVDEV driver for use in RTEMS | Kevin Kirspel | 2017-05-19 | 1 | -0/+1 |
* | Modify FREEBSD USB keyboard drivers for use in RTEMS | Kevin Kirspel | 2017-05-19 | 2 | -0/+2 |
* | Add USB UGEN support for RTEMS | Kevin Kirspel | 2017-05-19 | 1 | -1/+1 |
* | Adding RTEMS support for FREEBSD TTY | Kevin Kirspel | 2017-05-11 | 2 | -0/+3 |
