* | Port am335x usb driver to RTEMS. | Sichen Zhao | 2017-07-13 | 1 | -0/+0 |
| | | | | | | Add FDT and umass support for am335x USB driver. Now RTEMS can mount and open USB disk. | ||||
* | Use <sys/lock.h> provided by Newlib | Sebastian Huber | 2017-06-08 | 1 | -319/+0 |
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 3 | -705/+0 |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | ||||
* | Modify FREEBSD EVDEV driver for use in RTEMS | Kevin Kirspel | 2017-05-19 | 1 | -0/+1 |
* | Modify FREEBSD USB keyboard drivers for use in RTEMS | Kevin Kirspel | 2017-05-19 | 2 | -0/+2 |
* | Add USB UGEN support for RTEMS | Kevin Kirspel | 2017-05-19 | 1 | -1/+1 |
* | Adding RTEMS support for FREEBSD TTY | Kevin Kirspel | 2017-05-11 | 2 | -0/+3 |
* | Update to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-04-04 | 8 | -50/+870 |
| | | | | Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | ||||
* | FDT(4): Port to RTEMS | Sebastian Huber | 2017-03-08 | 3 | -0/+620 |
* | Port LPC32XX Ethernet and USB OHCI to RTEMS | Kevin Kirspel | 2017-02-14 | 1 | -0/+2 |
* | Add ordered Nexus devices | Kevin Kirspel | 2017-02-14 | 1 | -0/+6 |
| | | | | | Add support for ordering the initialization of Nexus devices. This can be used to make sure a device is initialized before a dependant device. | ||||
* | freebsd/wlanstats: Port to FreeBSD. | Christian Mauderer | 2017-01-17 | 1 | -0/+2 |
* | wlan/run: Add firmware. | Christian Mauderer | 2017-01-17 | 1 | -1/+1 |
* | rtwn: Port to RTEMS | Christian Mauderer | 2017-01-17 | 1 | -0/+0 |
* | Port USB and USB WLAN. | Christian Mauderer | 2017-01-17 | 1 | -0/+0 |
* | Port IEEE 802.11. | Christian Mauderer | 2017-01-17 | 2 | -0/+8 |
* | Use thread name support | Sebastian Huber | 2017-01-13 | 1 | -2/+0 |
| | | | | Update #2858. | ||||
* | ARP(8): Port to RTEMS | Sebastian Huber | 2017-01-10 | 1 | -0/+2 |
* | Update to FreeBSD head 2017-01-09 | Sebastian Huber | 2017-01-10 | 2 | -56/+254 |
| | | | | Git mirror commit 1f8e4a995a6ede4bdb24e6d335ccda2bdb0175ab. | ||||
* | Update to FreeBSD head 2016-12-10 | Sebastian Huber | 2017-01-10 | 1 | -1/+1 |
| | | | | Git mirror commit 80c55f08a05ab3b26a73b226ccb56adc3122a55c. | ||||
* | VMSTAT(8): Port to RTEMS | Sebastian Huber | 2017-01-10 | 1 | -0/+2 |
* | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 2017-01-10 | 22 | -97/+789 |
| | | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | Add a RTEMS Debugger TCP remote transport. | Chris Johns | 2016-11-29 | 1 | -0/+47 |
| | | | | | | | The patch also adds support to libbsd's build system making source conditional on a configure check. The debugger support is not available on all architectures and this feature lets us test if is avaliable. | ||||
* | Fix errno redefined warning | Sebastian Huber | 2016-11-14 | 1 | -0/+2 |
* | Modify rtems_bsd_set_vprintf_handler() | Sebastian Huber | 2016-11-09 | 1 | -3/+10 |
| | | | | Return previous vprintf()-handler in rtems_bsd_set_vprintf_handler(). | ||||
* | usb: Update to FreeBSD trunk 2016-08-23 | Sebastian Huber | 2016-08-23 | 2 | -2/+82 |
| | | | | FreeBSD trunk, 2016-08-23, 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | pfctl: Add rtems_bsd_command_pfctl. | Christian Mauderer | 2016-08-02 | 1 | -0/+2 |
* | Add telnetd as service to rc.conf. | Chris Johns | 2016-07-01 | 1 | -0/+5 |
* | Add ftpd initailize comment. | Chris Johns | 2016-06-30 | 1 | -0/+5 |
* | Add RTEMS_BSD_CONFIG_DOMAIN_PAGE_MBUFS_SIZE. | Chris Johns | 2016-06-30 | 1 | -0/+6 |
| | | | | | The domain allocator page abd mbuf size can be configured by the user using RTEMS_BSD_CONFIG_DOMAIN_PAGE_MBUFS_SIZE. | ||||
* | Add rtems_get_route to fetch a specific route from the routing tables. | Chris Johns | 2016-06-30 | 1 | -0/+48 |
* | Default syslog priority to INFO. Add rtems_setlogpriority to configure the ↵ | Chris Johns | 2016-06-30 | 1 | -0/+9 |
| | | | | | | | | | | priority. The rc.conf has 'syslog_priority' where the priority is the name, eg syslog_priority="debug" sets the priority to "debug". | ||||
* | Add ftpd as a service. Add rtems-bsd-config.h for app libbsd set up. | Chris Johns | 2016-06-28 | 1 | -0/+1 |
* | Make the domain allocation size global to allow it to set in tests. | Chris Johns | 2016-06-27 | 1 | -0/+7 |
| | | | | | | Some BSPs with multiple NIC locked in the tests due to not enough memory. This provides a simple per BSP way to increase the memory size. | ||||
* | ftpfs: Import from RTEMS | Sebastian Huber | 2016-06-10 | 1 | -0/+159 |
| | | | | RTEMS Git commit 251c94d3d3d27e0039f01b718e5c2eb06f39fdf7. | ||||
* | Directly use <sys/_types.h> provided by Newlib | Sebastian Huber | 2016-05-30 | 2 | -238/+1 |
* | Directly use <sys/types.h> provided by Newlib | Sebastian Huber | 2016-05-30 | 2 | -357/+1 |
* | Directly use <sys/time.h> provided by Newlib | Sebastian Huber | 2016-05-30 | 2 | -54/+1 |
* | subr_prf.c: Port to RTEMS | Sebastian Huber | 2016-05-06 | 1 | -0/+23 |
* | Add sbin/sysctl | Chris Johns | 2016-05-06 | 1 | -0/+2 |
* | rtems/bsd/bsd.h: Documentation | Sebastian Huber | 2016-04-27 | 1 | -1/+19 |
* | Add root bus support functions | Sebastian Huber | 2016-04-26 | 1 | -0/+32 |
* | intrmask_t: Provide dummy type definition | Sebastian Huber | 2016-04-18 | 1 | -2/+0 |
* | sys/time.h: Delete superfluous declaration | Sebastian Huber | 2016-04-06 | 1 | -2/+0 |
| | | | | Provided by RTEMS d2f9fa510f7e35cb86c056c57f51b416adf803bf. | ||||
* | USB: Update to FreeBSD trunk 2015-11-10 | Sebastian Huber | 2015-11-12 | 3 | -11/+478 |
* | Add the TCPDUMP command. | Chris Johns | 2015-06-16 | 1 | -0/+2 |
* | sys/time.h: Add missing define and declaration | Sebastian Huber | 2015-05-20 | 1 | -0/+3 |
* | Update due to API changes (timecounters) | Sebastian Huber | 2015-05-20 | 1 | -15/+15 |
* | Update to FreeBSD Stable/9 2015-04-08 | Sebastian Huber | 2015-05-20 | 2 | -29/+549 |
* | mii: Add phy devices | Sebastian Huber | 2015-04-01 | 1 | -1/+20 |
