* | Add zerocopy sendto | Sebastian Huber | 2015-02-13 | 1 | -0/+68 |
* | Update to FreeBSD 9.3 | Sebastian Huber | 2015-02-13 | 4 | -20/+1476 |
* | Add and use rtems_bsd_get_allocator_domain_size() | Sebastian Huber | 2015-02-13 | 1 | -0/+20 |
* | Add rtems_bsd_get_mac_address() | Sebastian Huber | 2015-01-21 | 1 | -0/+20 |
* | Add and use rtems_bsd_get_task_stack_size() | Sebastian Huber | 2015-01-20 | 1 | -0/+13 |
* | Add and use rtems_bsd_get_task_priority() | Sebastian Huber | 2015-01-20 | 1 | -1/+14 |
* | Add rtems_mdns_gethostname() | Sebastian Huber | 2014-11-10 | 1 | -3/+24 |
* | Fix spelling | Sebastian Huber | 2014-11-06 | 1 | -2/+2 |
* | Add rtems_mdns_sethostname() | Sebastian Huber | 2014-11-06 | 1 | -0/+17 |
| | | | | | Use it to set the multi-cast hostname of the default mDNS resolver instance via sethostname(). | ||||
* | HOSTNAME(1): Import from FreeBSD | Sebastian Huber | 2014-11-05 | 1 | -1/+2 |
* | Add mDNS support for name service dispatcher | Sebastian Huber | 2014-11-04 | 1 | -0/+74 |
* | Add rtems_bsd_force_select_timeout() | Sebastian Huber | 2014-11-04 | 1 | -0/+19 |
* | ppp: Port to new stack | Sebastian Huber | 2014-10-08 | 1 | -0/+0 |
* | ppp: Import from RTEMS sources | Sebastian Huber | 2014-10-08 | 3 | -0/+83 |
* | nexus: Use a linker set for the devices | Sebastian Huber | 2014-10-08 | 1 | -5/+12 |
* | Delete rtems_bsd_thread_chain | Sebastian Huber | 2014-09-25 | 2 | -14/+19 |
| | | | | Rely on RTEMS object registration for threads. | ||||
* | Disable IPsec | Sebastian Huber | 2014-09-23 | 2 | -2/+0 |
| | | | | | IPsec has a significant performance impact. Disable it for now since is only partially supported and untested. | ||||
* | Import and use subr_lock.c | Sebastian Huber | 2014-09-22 | 1 | -0/+0 |
* | telnetd: Import from RTEMS sources | Sebastian Huber | 2014-09-18 | 2 | -0/+178 |
* | DHCPCD(8): Add basic support | Sebastian Huber | 2014-01-30 | 1 | -0/+1 |
* | Add an ARP packet processor | Sebastian Huber | 2014-01-30 | 1 | -0/+20 |
* | Add rtems_bsd_get_ethernet_addr() | Sebastian Huber | 2014-01-30 | 1 | -0/+21 |
* | Add <rtems/bsd/util.h> | Sebastian Huber | 2014-01-30 | 1 | -0/+43 |
* | Delete rtems_bsd_initialize_with_interrupt_server | Sebastian Huber | 2013-12-20 | 1 | -2/+0 |
| | | | | Move interrupt server initialization to nexus_probe(). | ||||
* | BPF(4): Add support | Sebastian Huber | 2013-12-16 | 1 | -0/+1 |
* | Add support for boottimebin and getbinuptime() | Sebastian Huber | 2013-12-16 | 1 | -0/+9 |
* | Add RTEMS legacy MII support | Sebastian Huber | 2013-12-16 | 1 | -0/+139 |
* | ftpd01: New test | Sebastian Huber | 2013-12-16 | 1 | -0/+74 |
* | Changes due to <sys/cpuset.h> from latest Newlib | Sebastian Huber | 2013-12-04 | 1 | -0/+168 |
* | nexus: Add table based Nexus device initialization | Sebastian Huber | 2013-11-13 | 1 | -0/+22 |
* | Update to FreeBSD 9.2 | Sebastian Huber | 2013-11-11 | 10 | -329/+548 |
* | Move option defines to corresponding header files | Sebastian Huber | 2013-11-11 | 3 | -0/+3 |
* | Reduce divergence from FreeBSD sources | Sebastian Huber | 2013-11-11 | 1 | -0/+0 |
* | Update to FreeBSD 8.4 | Sebastian Huber | 2013-11-04 | 11 | -1848/+5640 |
* | Do not use FreeBSD time control | Sebastian Huber | 2013-10-31 | 1 | -0/+65 |
* | Move integer type definitions | Sebastian Huber | 2013-10-31 | 2 | -6/+14 |
* | Update from latest FreeBSD version | Sebastian Huber | 2013-10-31 | 1 | -0/+2 |
* | Use Newlib provided <sys/fcntl.h> | Sebastian Huber | 2013-10-31 | 1 | -0/+3 |
* | Provide __socklen_t, use size_t for socklen_t | Sebastian Huber | 2013-10-31 | 1 | -1/+2 |
* | Update files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 11 | -78/+287 |
| | | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | ||||
* | Move files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 74 | -0/+25256 |
