path: root/rtemsbsd/include/rtems/bsd/local/opt_syscons.h (unfollow)
2019-08-11fbd: Port to RTEMSVijay Kumar Banerjee1-0/+0
2018-01-23sdk_dpaa: Port to RTEMSSebastian Huber1-0/+0
Update #3277.
2017-01-10VMSTAT(8): Port to RTEMSSebastian Huber1-0/+0
2016-08-23mmc: Update to FreeBSD trunk 2016-08-23Sebastian Huber1-0/+0
2013-10-10Update files to match FreeBSD layoutSebastian Huber1-1/+0
Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests.
2013-10-10Move files to match FreeBSD layoutSebastian Huber1-0/+0
2012-03-30Add freebsd/machine/elf.h as empty. Improve message for empty file.Joel Sherrill1-0/+0
2012-03-08Move rtems/freebsd to freebsd and contrib to freebsd/contribJoel Sherrill1-0/+0
