* | Add wpa_supplicant_fork command. | Sichen Zhao | 2017-11-10 | 1 | -0/+2 | |
| | | | | Add fork command for wpa supplicant to start a new task. | |||||
* | Port wpa supplicant to RTEMS. | Sichen Zhao | 2017-11-10 | 2 | -0/+43 | |
| | | | | Add wpa_supplicant lib support and shell command support in RTEMS. | |||||
* | Port BBB sd driver files to RTEMS. | Sichen Zhao | 2017-11-10 | 1 | -0/+0 | |
| | | | | So BBB can mount and read eMMC and SD card. | |||||
* | Import CRC32 support from FreeBSD | Sebastian Huber | 2017-10-20 | 1 | -0/+2 | |
* | blist: Import from FreeBSD | Sebastian Huber | 2017-10-20 | 1 | -0/+6 | |
* | Fix INVARIANTS support | Sebastian Huber | 2017-10-20 | 1 | -4/+18 | |
* | user-space: Define O_DIRECTORY | Sebastian Huber | 2017-10-10 | 1 | -0/+2 | |
* | if-atsam: Port to rtems-libbsd. | Christian Mauderer | 2017-09-22 | 1 | -0/+8 | |
* | BUS_SPACE(9): 64-bit support | Sebastian Huber | 2017-08-23 | 1 | -3/+3 | |
| | | | | Update #3082. | |||||
* | Port am335x usb driver to RTEMS. | Sichen Zhao | 2017-07-13 | 1 | -0/+0 | |
| | | | | | | Add FDT and umass support for am335x USB driver. Now RTEMS can mount and open USB disk. | |||||
* | Use <sys/lock.h> provided by Newlib | Sebastian Huber | 2017-06-08 | 3 | -2/+321 | |
* | Update due to Newlib 2017-06-07 changes | Sebastian Huber | 2017-06-08 | 8 | -169/+13 | |
| | | | | | | | | | | | | | | | | | The following files are now provided by Newlib: * arpa/inet.h * net/if.h * netinet/in.h * netinet/tcp.h * sys/socket.h * sys/uio.h * sys/un.h The <sys/param.h> and <sys/cpuset.h> are now compatible enough to be used directly. Update #2833. | |||||
* | Add LPC32XX touch screen driver | Kevin Kirspel | 2017-05-19 | 1 | -0/+22 | |
* | Add bitcount inlinesfor RTEMS. These are found in FREEBSDs types.h | Kevin Kirspel | 2017-05-19 | 1 | -0/+107 | |
* | Adding RTEMS support for FREEBSD TTY | Kevin Kirspel | 2017-05-11 | 2 | -0/+3 | |
* | Update to FreeBSD head 2017-04-04 | Sebastian Huber | 2017-04-04 | 2 | -7/+866 | |
| | | | | Git mirror commit 642b174daddbd0efd9bb5f242c43f4ab4db6869f. | |||||
* | FDT(4): Port to RTEMS | Sebastian Huber | 2017-03-08 | 1 | -0/+10 | |
* | Fix dw_mmc dependencies | Sebastian Huber | 2017-03-01 | 1 | -2/+1 | |
* | Add poll() and select() support for Termios | Sebastian Huber | 2017-02-28 | 1 | -0/+11 | |
* | Port LPC32XX Ethernet and USB OHCI to RTEMS | Kevin Kirspel | 2017-02-14 | 1 | -0/+75 | |
* | Add support for LPC32XX cache | Kevin Kirspel | 2017-02-14 | 1 | -5/+2 | |
* | rtems-bsd-mutex: Use thread queue name | Sebastian Huber | 2017-01-31 | 1 | -1/+1 | |
* | freebsd/wlanstats: Port to FreeBSD. | Christian Mauderer | 2017-01-17 | 1 | -0/+2 | |
* | lib80211/regdomain: Port to RTEMS. | Christian Mauderer | 2017-01-17 | 1 | -0/+15 | |
* | rtems-bsd-mutex: Add SMP lock debug support | Sebastian Huber | 2017-01-11 | 1 | -1/+8 | |
* | Declare feature_present() | Sebastian Huber | 2017-01-10 | 1 | -0/+3 | |
* | ARP(8): Port to RTEMS | Sebastian Huber | 2017-01-10 | 1 | -0/+2 | |
* | Update to FreeBSD head 2017-01-09 | Sebastian Huber | 2017-01-10 | 1 | -8/+22 | |
| | | | | Git mirror commit 1f8e4a995a6ede4bdb24e6d335ccda2bdb0175ab. | |||||
* | Update to FreeBSD head 2016-12-10 | Sebastian Huber | 2017-01-10 | 1 | -0/+2 | |
| | | | | Git mirror commit 80c55f08a05ab3b26a73b226ccb56adc3122a55c. | |||||
* | VMSTAT(8): Port to RTEMS | Sebastian Huber | 2017-01-10 | 1 | -1/+3 | |
* | Enable multi-cast routing support | Sebastian Huber | 2017-01-10 | 2 | -0/+20 | |
* | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 2017-01-10 | 6 | -675/+871 | |
| | | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | |||||
* | Add BRIDGE(4) support to configuration | Sebastian Huber | 2016-12-15 | 2 | -3/+17 | |
* | Provide O_CLOEXEC | Sebastian Huber | 2016-11-09 | 1 | -0/+2 | |
* | Provide CLOCK_UPTIME | Sebastian Huber | 2016-11-09 | 1 | -0/+4 | |
* | Add thread fences to <machine/atomic.h> | Sebastian Huber | 2016-11-09 | 1 | -0/+52 | |
* | Add empty <machine/_kernel_lock.h> | Sebastian Huber | 2016-11-09 | 1 | -0/+0 | |
* | rtems-bsd-mutex: Optimize | Sebastian Huber | 2016-11-09 | 1 | -11/+52 | |
| | | | | Inline SMP lock acquire/release. Avoid stack frame for hot path. | |||||
* | rtems-bsd-mutex: Update due to API changes | Sebastian Huber | 2016-11-03 | 1 | -3/+3 | |
* | rtemsbsd: Add reallocf to rtems_bsd_program. | Christian Mauderer | 2016-10-24 | 1 | -0/+7 | |
* | Add SIZE_T_MAX to <machine/rtems-bsd-user-space.h> | Sebastian Huber | 2016-10-24 | 1 | -0/+2 | |
* | Provide CLOCK_MONOTONIC_FAST | Sebastian Huber | 2016-10-24 | 1 | -0/+4 | |
* | Make <machine/atomic.h> available to user space | Sebastian Huber | 2016-10-24 | 1 | -4/+0 | |
| | | | | Enables use of <sys/refcount.h> in user space. | |||||
* | rtems-bsd-mutex: Update due to API changes | Sebastian Huber | 2016-09-22 | 1 | -25/+11 | |
* | rtems-bsd-mutex: Use _Thread_queue_Surrender() | Sebastian Huber | 2016-08-11 | 1 | -6/+7 | |
* | pf: Add configuration via rc.conf. | Christian Mauderer | 2016-08-08 | 2 | -0/+5 | |
* | pf: Add RTEMS_BSD_CONFIG_FIREWALL_xxx options. | Christian Mauderer | 2016-08-08 | 1 | -0/+28 | |
* | freebsd: Add constant ipv6 addresses from vars.c. | Christian Mauderer | 2016-08-04 | 1 | -3/+0 | |
| | | | | This is necessary for a configuration without IPv6. | |||||
* | pfctl: Add rtems_bsd_command_pfctl. | Christian Mauderer | 2016-08-02 | 1 | -0/+2 | |
* | rtemsbsd: Add wrapper for open, fopen, malloc, ... | Christian Mauderer | 2016-08-02 | 1 | -1/+91 | |
| | | | | | | | | | | | | | | | | | Add the following rtems_bsd_program_... wrapper: * rtems_bsd_program_open * rtems_bsd_program_socket * rtems_bsd_program_close * rtems_bsd_program_fopen * rtems_bsd_program_fclose * rtems_bsd_program_malloc * rtems_bsd_program_calloc * rtems_bsd_program_realloc * rtems_bsd_program_free * rtems_bsd_program_strdup * rtems_bsd_program_vasprintf * rtems_bsd_program_asprintf |
