* | SOCKETPAIR(2): Port to RTEMS | Sebastian Huber | 2015-11-16 | 1 | -0/+2 |
* | Update to FreeBSD 9.2 | Sebastian Huber | 2013-11-11 | 1 | -2/+4 |
* | Use kqueue() and kevent() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+9 |
* | Use poll() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+3 |
* | Add sysctl(), etc. prototypes | Sebastian Huber | 2013-10-31 | 1 | -0/+7 |
* | Use send/recv functions from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+8 |
| | | | | Use recvfrom(), recvmsg(), sendto() and sendmsg() from FreeBSD. | ||||
* | Use getsockname() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+2 |
* | Use getpeername() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+2 |
* | Use getsockopt() and setsockopt() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+4 |
* | Use accept() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+2 |
* | Use listen() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+2 |
* | Use connect() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+2 |
* | Use bind() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+2 |
* | Use shutdown() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+2 |
* | Import socket() implementation from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+3 |
| | | | | Add new test syscalls01. | ||||
* | Update files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 1 | -0/+59 |
Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. |
