* | mutex: Avoid NULL pointer access in panic() | Sebastian Huber | 2018-11-15 | 1 | -1/+2 |
* | mutex: Use panic() after ISR lock release | Sebastian Huber | 2018-03-13 | 1 | -3/+18 |
| | | | | | | Using panic() with interrupts disabled could lead to an additional error (INTERNAL_ERROR_BAD_THREAD_DISPATCH_ENVIRONMENT) due to a potentially blocking output. | ||||
* | Fix INVARIANTS support | Sebastian Huber | 2017-10-20 | 1 | -4/+18 |
* | Use <sys/lock.h> provided by Newlib | Sebastian Huber | 2017-06-08 | 1 | -1/+1 |
* | rtems-bsd-mutex: Use thread queue name | Sebastian Huber | 2017-01-31 | 1 | -1/+1 |
* | rtems-bsd-mutex: Add SMP lock debug support | Sebastian Huber | 2017-01-11 | 1 | -1/+8 |
* | rtems-bsd-mutex: Optimize | Sebastian Huber | 2016-11-09 | 1 | -11/+52 |
| | | | | Inline SMP lock acquire/release. Avoid stack frame for hot path. | ||||
* | rtems-bsd-mutex: Update due to API changes | Sebastian Huber | 2016-11-03 | 1 | -3/+3 |
* | rtems-bsd-mutex: Update due to API changes | Sebastian Huber | 2016-09-22 | 1 | -25/+11 |
* | rtems-bsd-mutex: Use _Thread_queue_Surrender() | Sebastian Huber | 2016-08-11 | 1 | -6/+7 |
* | rtems-bsd-mutex: Update due to API changes | Sebastian Huber | 2016-07-28 | 1 | -11/+10 |
* | rtems-bsd-mutex: Update due to API changes | Sebastian Huber | 2016-05-30 | 1 | -3/+3 |
* | Directly use <sys/types.h> provided by Newlib | Sebastian Huber | 2016-05-30 | 1 | -1/+1 |
* | rtems-bsd-mutex: Update due to API changes | Sebastian Huber | 2016-05-25 | 1 | -14/+17 |
* | rtems-bsd-mutex: Update due to API changes | Sebastian Huber | 2016-04-06 | 1 | -1/+1 |
* | rtems-bsd-mutex: Fix mtx_destroy() | Sebastian Huber | 2016-04-06 | 1 | -1/+1 |
* | rtems-bsd-mutex: Update due to API changes | Sebastian Huber | 2015-07-24 | 1 | -6/+7 |
* | rtems-bsd-mutex: Fix resource count updates | Sebastian Huber | 2015-06-23 | 1 | -1/+1 |
* | rtems-bsd-mutex: Use standard thread queues | Sebastian Huber | 2015-05-20 | 1 | -14/+22 |
* | rtems-bsd-mutex: Update due to API changes | Sebastian Huber | 2015-04-23 | 1 | -6/+4 |
* | rtems-bsd-mutex: Support priority changes | Sebastian Huber | 2015-03-26 | 1 | -3/+5 |
* | rtems_bsd_mutex: SMP support via ISR locks | Sebastian Huber | 2015-03-06 | 1 | -20/+25 |
* | rtems_bsd_mutex: Optimize | Sebastian Huber | 2014-09-24 | 1 | -50/+23 |
* | Replace RTEMS objects with custom implementation | Sebastian Huber | 2014-09-23 | 1 | -0/+220 |
Performance analysis revealed that the standard RTEMS objects are a major bottleneck. The object get mechanism and attribute checks at runtime have a significant overhead. Use a custom implementation for synchronization primitives. This drops also the size of the synchronization primitives considerably. |
