* | rtems_bsd_mutex: SMP support via ISR locks | Sebastian Huber | 2015-03-06 | 1 | -1/+3 |
* | Replace RTEMS objects with custom implementation | Sebastian Huber | 2014-09-23 | 1 | -0/+60 |
Performance analysis revealed that the standard RTEMS objects are a major bottleneck. The object get mechanism and attribute checks at runtime have a significant overhead. Use a custom implementation for synchronization primitives. This drops also the size of the synchronization primitives considerably. |
