* | Update files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 1 | -8/+30 |
| | | | | | | | | | | | | | | | | | | | Add compatibility with Newlib header files. Some FreeBSD header files are mapped by the translation script: o rtems/bsd/sys/_types.h o rtems/bsd/sys/errno.h o rtems/bsd/sys/lock.h o rtems/bsd/sys/param.h o rtems/bsd/sys/resource.h o rtems/bsd/sys/time.h o rtems/bsd/sys/timespec.h o rtems/bsd/sys/types.h o rtems/bsd/sys/unistd.h It is now possible to include <sys/socket.h> directly for example. Generate one Makefile which builds everything including tests. | ||||
* | Move files to match FreeBSD layout | Sebastian Huber | 2013-10-10 | 1 | -0/+10 |
* | Preserve Sebastian's directory structure under rtemsbsd to minimize changes | Joel Sherrill | 2012-03-07 | 1 | -30/+0 |
* | Separate RTEMS Specific Files from Those Direct from FreeBSD | Joel Sherrill | 2012-03-07 | 1 | -0/+30 |
