* | fbd: Port to RTEMS | Vijay Kumar Banerjee | 2019-08-11 | 1 | -0/+3 |
* | TDA19988: Port to RTEMS | Vijay Kumar Banerjee | 2019-08-11 | 1 | -0/+1 |
* | Pinmux: Port to RTEMS | Vijay Kumar Banerjee | 2019-08-11 | 1 | -0/+1 |
* | iicbus: port to RTEMS | Vijay Kumar Banerjee | 2019-06-29 | 1 | -0/+4 |
* | freebsd/if_cpsw: Port. | Christian Mauderer | 2018-12-20 | 1 | -0/+2 |
* | Fix typo (RTEMS_BSD_MODULE_NET80211) | Sebastian Huber | 2018-10-02 | 1 | -2/+2 |
* | fsl_sdhci.c: Port to RTEMS | Sebastian Huber | 2018-09-25 | 1 | -0/+3 |
| | | | | Update #3525. | ||||
* | imx/imx_gpio.c: Port to RTEMS | Sebastian Huber | 2018-09-25 | 1 | -0/+2 |
* | if_ffec_mpc8xx: New MDIO driver support | Sebastian Huber | 2018-09-21 | 1 | -0/+1 |
| | | | | Update #3523. | ||||
* | if_ffec_mpc8xx: Port driver to libbsd | Sebastian Huber | 2018-09-21 | 1 | -0/+4 |
* | beagle: Disable WiFi if libbsd is build without it. | Christian Mauderer | 2018-06-05 | 1 | -0/+3 |
| | | | | Update #3351. | ||||
* | Add device tree support for Altera/Intel Cyclone V | Sebastian Huber | 2018-02-06 | 1 | -10/+10 |
| | | | | Close #3290. | ||||
* | sdk_dpaa: Port to RTEMS | Sebastian Huber | 2018-01-23 | 1 | -0/+8 |
| | | | | Update #3277. | ||||
* | Port wpa supplicant to RTEMS. | Sichen Zhao | 2017-11-10 | 1 | -0/+2 |
| | | | | Add wpa_supplicant lib support and shell command support in RTEMS. | ||||
* | Port BBB sd driver files to RTEMS. | Sichen Zhao | 2017-11-10 | 1 | -0/+2 |
| | | | | So BBB can mount and read eMMC and SD card. | ||||
* | Import DPAA driver snapshot | Sebastian Huber | 2017-10-23 | 1 | -2/+13 |
| | | | | | | | | | | Imported from Freescale Linux repository git://git.freescale.com/ppc/upstream/linux.git commit 2774c204cd8bfc56a200ff4dcdfc9cdf5b6fc161. Linux compatibility layer is partly from FreeBSD. | ||||
* | ffec: Port to RTEMS | Sebastian Huber | 2017-09-27 | 1 | -0/+7 |
* | if-atsam: Port to rtems-libbsd. | Christian Mauderer | 2017-09-22 | 1 | -0/+2 |
* | Enable the WEP encrypted WiFi. | Sichen Zhao | 2017-08-02 | 1 | -0/+1 |
| | | | | Now rtems can connnect WiFi via WEP on rtl8188eu chip. | ||||
* | Port rtl8188eu driver to RTEMS. | Sichen Zhao | 2017-08-02 | 1 | -0/+5 |
| | | | | | Now USB dongle rtl8188eu can work as wlan client device. It can scan wifi, connect unencrypted wifi. | ||||
* | Port am335x usb driver to RTEMS. | Sichen Zhao | 2017-07-13 | 1 | -0/+14 |
| | | | | | | Add FDT and umass support for am335x USB driver. Now RTEMS can mount and open USB disk. | ||||
* | Add LPC32XX touch screen driver | Kevin Kirspel | 2017-05-19 | 1 | -0/+1 |
* | nexus-devices: Use FDT for qoriq BSPs | Sebastian Huber | 2017-04-04 | 1 | -4/+4 |
* | Port LPC32XX Ethernet and USB OHCI to RTEMS | Kevin Kirspel | 2017-02-14 | 1 | -0/+12 |
* | Update to FreeBSD head 2016-08-23 | Sebastian Huber | 2017-01-10 | 1 | -1/+1 |
| | | | | Git mirror commit 9fe7c416e6abb28b1398fd3e5687099846800cfd. | ||||
* | nexus-devices: Support arm/lpc24xx | Sebastian Huber | 2016-10-07 | 1 | -0/+7 |
* | nexus-devices: Add arm/atsamv BSP section | Sebastian Huber | 2016-09-28 | 1 | -0/+5 |
* | Change the Nexus bus to defines and have the BSP declare them. | Chris Johns | 2016-06-28 | 1 | -36/+27 |
* | Move the Nexus bus driver decls available to users. | Chris Johns | 2016-06-27 | 1 | -114/+42 |
* | Add RealTek Gig PHY. | Chris Johns | 2016-05-04 | 1 | -0/+2 |
* | pc386: Add RealTek network driver to the nexus bus. | Chris Johns | 2016-04-28 | 1 | -0/+1 |
* | dwc_otg: Port to RTEMS | Sebastian Huber | 2015-11-12 | 1 | -0/+19 |
* | nexus-devices: Add pc386 nexus device and drivers | Sebastian Huber | 2015-07-31 | 1 | -0/+10 |
* | Update due to header guard changes | Sebastian Huber | 2015-07-23 | 1 | -1/+1 |
* | if_dwc: Add Altera Cyclone V support | Sebastian Huber | 2015-04-01 | 1 | -0/+20 |
* | mmc: Import MMC/SDCard support from libusb | Sebastian Huber | 2015-03-26 | 1 | -0/+7 |
* | nexus-devices: Fix for QorIQ T variants | Sebastian Huber | 2015-03-26 | 1 | -4/+8 |
* | if_tsec: Add Nexus support | Sebastian Huber | 2015-02-13 | 1 | -1/+28 |
* | Add Xilinx Zynq BSP support | Sebastian Huber | 2015-01-21 | 1 | -0/+32 |
* | nexus-devices: Only register fec0 | Sebastian Huber | 2014-10-31 | 1 | -2/+0 |
| | | | | This makes testing of IPv4LL a bit easier. | ||||
* | nexus: Use a linker set for the devices | Sebastian Huber | 2014-10-08 | 1 | -0/+61 |
