* | rtems_waf: Update to origin/master. | Chris Johns | 2020-04-06 | 1 | -0/+0 |
| | | | | Closes #3888. | ||||
* | rtems_waf: Update to master (096372fc4504) | Chris Johns | 2020-02-28 | 1 | -0/+0 |
| | | | | Closes #3888 | ||||
* | Update rtems_waf | Sebastian Huber | 2018-10-25 | 1 | -0/+0 |
| | | | | Update #3551. | ||||
* | rtems_waf: Fix show-commands option. | Christian Mauderer | 2018-06-18 | 1 | -0/+0 |
* | waf: Add configurations with different modules. | Christian Mauderer | 2018-04-10 | 1 | -0/+0 |
| | | | | Update #3351 | ||||
* | Update to bring in the --show-commands fix. | Chris Johns | 2016-07-09 | 1 | -0/+0 |
* | Update rtems_waf to pick up the long command line fix. | Chris Johns | 2016-06-20 | 1 | -0/+0 |
* | Pick up white space fix. | Chris Johns | 2016-06-16 | 1 | -0/+0 |
* | Add support for long command lines and fix some shell rules on Windows. | Chris Johns | 2016-06-16 | 1 | -0/+0 |
* | Get rtems_waf fix for command expansion. | Chris Johns | 2016-05-11 | 1 | -0/+0 |
* | Update rtems_waf with the latest fixes. | Chris Johns | 2016-05-07 | 1 | -0/+0 |
* | Update the rtems_waf submodule. | Chris Johns | 2016-04-18 | 1 | -0/+0 |
* | Add RTEMS version support, update all python to 2 and 3. | Chris Johns | 2016-04-18 | 1 | -0/+0 |
| | | | | | | | | | | | | | Add support to force the RTEMS version. This remove the need for using the --rtems-version command line option if the automatic detection fails. Update all python code to support python 2 and 3. Update rtems_waf to the latest version to support the RTEMS version, check environment variables and to display the CC version. Sort all tests. I think the unsorted list is dependent on the version of python and so would result in repo noise as if it regenerted. | ||||
* | Update rtems_waf module for msys2 support | Sebastian Huber | 2015-11-16 | 1 | -0/+0 |
* | Update rtems_waf module for Python 3 compatibility | Sebastian Huber | 2015-11-13 | 1 | -0/+0 |
* | Update rtems_waf module for msys2 support | Sebastian Huber | 2015-11-13 | 1 | -0/+0 |
* | Use latest rtems_waf | Sebastian Huber | 2015-11-13 | 1 | -0/+0 |
* | Add support to build using waf. | Chris Johns | 2015-05-20 | 1 | -0/+0 |
