path: root/mDNSResponder (unfollow)
2019-06-12Remove junk folders.Chris Johns2-0/+0
2018-10-16mDNSResponder: Fix for update to v765.1.2Sebastian Huber1-0/+4
In the update to v765.1.2 the mDNS_Init() changed the initialization of m->AutoTargetServices from 1 to 0. The motivation for this change is unclear. This change prevents at least the mDNS hostname lookups. Revert this change and initialize m->AutoTargetServices to 1 like it was before the update.
2018-10-16mDNSResponder: Fix use of uninitialized variablesSebastian Huber1-0/+9
2018-10-02mDNSResponder: Do not use SO_RECV_ANYIF socket optSebastian Huber1-0/+2
This socket option is not supported by FreeBSD.
2018-09-20mDNSResponder: Update to v878.30.4Sebastian Huber10-355/+782
The sources can be obtained via: https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-878.30.4.tar.gz Close #3522.
2018-09-20mDNSResponder: Update to v878.20.3Sebastian Huber3-86/+269
The sources can be obtained via: https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-878.20.3.tar.gz Update #3522.
2018-09-20mDNSResponder: Update to v878.1.1Sebastian Huber164-5525/+28521
The sources can be obtained via: https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-878.1.1.tar.gz Update #3522.
2018-09-20mDNSResponder: Update to v765.50.9Sebastian Huber14-109/+133
The sources can be obtained via: https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-765.50.9.tar.gz Update #3522.
2018-09-20mDNSResponder: Update to v765.30.11Sebastian Huber11-121/+112
The sources can be obtained via: https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-765.30.11.tar.gz Update #3522.
2018-09-20mDNSResponder: Update to v765.20.4Sebastian Huber5-14/+25
The sources can be obtained via: https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-765.20.4.tar.gz Update #3522.
2018-09-20mDNSResponder: Update to v765.1.2Sebastian Huber110-7838/+11487
The sources can be obtained via: https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-765.1.2.tar.gz Move mDNS_StartResolveService() and mDNS_StopResolveService() to an RTEMS-specific file (rtemsbsd/mdns/mDNSResolveService.c) using the v576.30.4 implementation. Apple removed these functions without explanation. Update #3522.
2018-09-20mDNSResponder: Update to v625.41.2Sebastian Huber120-7537/+3681
The sources can be obtained via: https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-625.41.2.tar.gz Update #3522.
2018-09-20mDNSResponder: Update to v576.30.4Sebastian Huber25-208/+446
The sources can be obtained via: https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-576.30.4.tar.gz Update #3522.
2018-09-20mDNSResponder: Update to v567Sebastian Huber24-171/+308
The sources can be obtained via: https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-567.tar.gz Update #3522.
2018-09-20mDNSResponder: Update to v561.1.1Sebastian Huber12-114/+138
The sources can be obtained via: https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-561.1.1.tar.gz Update #3522.
2018-09-20mDNSResponder: Fix gAllocatedEventFDs allocationSebastian Huber1-1/+1
2018-09-19mDNSResponder: Honour file descriptor maximumSebastian Huber1-0/+30
Dynamically allocate a big enough file descriptor set for select(). A better solution would be to use kqueue() instead of select().
2014-11-04mDNS: Avoid uninitialized memorySebastian Huber2-3/+3
Use calloc() instead of malloc().
2014-01-30mDNS: Use mutex for mDNSPosix platformSebastian Huber2-0/+23
2014-01-30mDNS: mDNSShared/mDNSDebug.cSebastian Huber1-0/+4
Avoid reference to ProgramName.
2014-01-30mDNS: mDNSShared/dnssd_clientshim.cSebastian Huber1-1/+11
Fix typos. Include missing header files.
2014-01-30mDNS: AnonInfoAnswersQuestion: Fix stack usageSebastian Huber1-5/+10
The mDNSexport is normally defined to be empty, thus mDNSStorage is a huge stack variable (roughly 50KiB) with random data. Asuming a global mDNSStorage variable in the mDNSCore makes no sense.
2014-01-30mDNS: ImportSebastian Huber578-0/+195006
The sources can be obtained via: http://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-544.tar.gz
