This socket option is not supported by FreeBSD.
The sources can be obtained via:
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-878.1.1.tar.gz
Update #3522.
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-765.30.11.tar.gz
Update #3522.
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-765.1.2.tar.gz
Move mDNS_StartResolveService() and mDNS_StopResolveService() to an
RTEMS-specific file (rtemsbsd/mdns/mDNSResolveService.c) using the
v576.30.4 implementation. Apple removed these functions without
explanation.
Update #3522.
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-625.41.2.tar.gz
Update #3522.
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-576.30.4.tar.gz
Update #3522.
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-567.tar.gz
Update #3522.
Dynamically allocate a big enough file descriptor set for select(). A
better solution would be to use kqueue() instead of select().
Use calloc() instead of malloc().
http://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-544.tar.gz
