Update #4010.
The sources can be obtained via:
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-878.270.2.tar.gz
Update #4010.
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-878.260.1.tar.gz
Update #4010.
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-878.240.1.tar.gz
Update #4010.
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-878.230.2.tar.gz
Update #4010.
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-878.200.35.tar.gz
Update #4010.
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-878.70.2.tar.gz
Update #4010.
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-878.50.17.tar.gz
Update #4010.
Update #4010.
In the update to v765.1.2 the mDNS_Init() changed the initialization of
m->AutoTargetServices from 1 to 0. The motivation for this change is
unclear. This change prevents at least the mDNS hostname lookups.
Revert this change and initialize m->AutoTargetServices to 1 like it was
before the update.
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-878.30.4.tar.gz
Close #3522.
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-878.1.1.tar.gz
Update #3522.
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-765.50.9.tar.gz
Update #3522.
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-765.30.11.tar.gz
Update #3522.
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-765.1.2.tar.gz
Move mDNS_StartResolveService() and mDNS_StopResolveService() to an
RTEMS-specific file (rtemsbsd/mdns/mDNSResolveService.c) using the
v576.30.4 implementation. Apple removed these functions without
explanation.
Update #3522.
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-625.41.2.tar.gz
Update #3522.
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-576.30.4.tar.gz
Update #3522.
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-567.tar.gz
Update #3522.
The mDNSexport is normally defined to be empty, thus mDNSStorage is a
huge stack variable (roughly 50KiB) with random data.
Asuming a global mDNSStorage variable in the mDNSCore makes no sense.
http://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-544.tar.gz
