* | PIPE(2): Port to RTEMS | Kevin Kirspel | 2016-12-23 | 1 | -0/+1 |
* | Add a RTEMS Debugger TCP remote transport. | Chris Johns | 2016-11-29 | 1 | -7/+20 |
| | | | | | | | The patch also adds support to libbsd's build system making source conditional on a configure check. The debugger support is not available on all architectures and this feature lets us test if is avaliable. | ||||
* | Use -Wno-pointer-sign | Sebastian Huber | 2016-11-14 | 1 | -0/+1 |
| | | | | Pointer sign warnings are quite common in FreeBSD code. | ||||
* | SDHCI(4): Delete | Sebastian Huber | 2016-11-09 | 1 | -1/+0 |
| | | | | | Delete heavily modified SDHCI(4) support. It must be re-imported from a later FreeBSD version on demand. | ||||
* | Remove AppleTalk support | Sebastian Huber | 2016-10-13 | 1 | -11/+0 |
| | | | | Prepare update to FreeBSD 11. | ||||
* | usb01: Simplify test program | Sebastian Huber | 2016-09-28 | 1 | -2/+1 |
* | Split rtemsbsd/rtems/rtems-program.c | Sebastian Huber | 2016-09-28 | 1 | -0/+1 |
| | | | | This improves garbage collection by the linker. | ||||
* | Split rtems-bsd-kernel-program.c | Sebastian Huber | 2016-09-28 | 1 | -0/+1 |
| | | | | Separate kernel and user space parts. | ||||
* | Build rtems-bsd-shell-pfctl.c | Sebastian Huber | 2016-09-28 | 1 | -0/+1 |
* | Split rtems-bsd-shell-netcmds.c | Sebastian Huber | 2016-09-28 | 1 | -1/+6 |
* | Port getdomainname() to RTEMS | Sebastian Huber | 2016-09-07 | 1 | -0/+1 |
* | pf: Add configuration via rc.conf. | Christian Mauderer | 2016-08-08 | 1 | -0/+1 |
* | freebsd: Add constant ipv6 addresses from vars.c. | Christian Mauderer | 2016-08-04 | 1 | -0/+1 |
| | | | | This is necessary for a configuration without IPv6. | ||||
* | testsuite/pf02: Add interactive pf test. | Christian Mauderer | 2016-08-03 | 1 | -1/+11 |
* | pfctl: build files. | Christian Mauderer | 2016-08-02 | 1 | -0/+20 |
* | testsuite/syscalls01: Split out program01 part. | Christian Mauderer | 2016-08-02 | 1 | -1/+11 |
| | | | | | | This allows to use normal functions for sockets and similar while allowing to test the upcoming rtems_bsd_program_opan/close/... for the program part. | ||||
* | testsuite/pf01: Add test that links PF. | Christian Mauderer | 2016-08-01 | 1 | -0/+10 |
* | testsuite/cdev01: Add test for cdev functions. | Christian Mauderer | 2016-08-01 | 1 | -0/+11 |
* | kern_conf.c: Adapt for RTEMS. | Christian Mauderer | 2016-08-01 | 1 | -1/+1 |
* | rtemsbsd/devfs: Add. | Christian Mauderer | 2016-08-01 | 1 | -0/+1 |
* | Add telnetd as service to rc.conf. | Chris Johns | 2016-07-01 | 1 | -0/+2 |
* | Add RTEMS_BSD_CONFIG_DOMAIN_PAGE_MBUFS_SIZE. | Chris Johns | 2016-06-30 | 1 | -0/+1 |
| | | | | | The domain allocator page abd mbuf size can be configured by the user using RTEMS_BSD_CONFIG_DOMAIN_PAGE_MBUFS_SIZE. | ||||
* | Add rtems_get_route to fetch a specific route from the routing tables. | Chris Johns | 2016-06-30 | 1 | -0/+1 |
* | Add ftpd as a service. Add rtems-bsd-config.h for app libbsd set up. | Chris Johns | 2016-06-28 | 1 | -0/+2 |
* | Add a services base test. | Chris Johns | 2016-06-27 | 1 | -0/+10 |
* | Add support for long command lines and fix some shell rules on Windows. | Chris Johns | 2016-06-16 | 1 | -9/+17 |
* | nfsclient: Port to LibBSD | Sebastian Huber | 2016-06-10 | 1 | -0/+14 |
* | XDR(3): Port to RTEMS | Sebastian Huber | 2016-06-10 | 1 | -0/+8 |
* | RPC(3): Port to RTEMS | Sebastian Huber | 2016-06-10 | 1 | -0/+55 |
* | ftpfs: Import from RTEMS | Sebastian Huber | 2016-06-10 | 1 | -0/+11 |
| | | | | RTEMS Git commit 251c94d3d3d27e0039f01b718e5c2eb06f39fdf7. | ||||
* | Add support for rc.conf(5) initialisation. | Chris Johns | 2016-05-18 | 1 | -0/+12 |
| | | | | | | | | | | | | | | | | | | | | | | | | Provide user support for rc.conf(5) so a user can create a suitable /etc/rc.conf file to initialise libbsd. This patch by default adds basic networking support: cloned_interfaces ifconfig_'interface' defaultrouter hostname Refer to FreeBSD documentation for examples. Users can make a single call to have /etc/rc.conf processed, or pass a file name to a specific configuration file or a text string with line feeds can be passed to the scripting version of the interface. The rc.conf support is implemented in terms of directive handlers that are called based on a regular expression. The design allows new handlers to be added as needed. Line concatenation is still to be implemented. | ||||
* | Add namespace support for kvm | Sebastian Huber | 2016-05-06 | 1 | -2/+2 |
* | Rename files for kernel namespace script | Sebastian Huber | 2016-05-06 | 1 | -36/+36 |
| | | | | This makes it easier to create the kernel namespace header. | ||||
* | subr_prf.c: Port to RTEMS | Sebastian Huber | 2016-05-06 | 1 | -2/+13 |
* | Revert "Move network-config.h to the top of the testsuite include path." | Sebastian Huber | 2016-05-06 | 1 | -1/+1 |
| | | | | This reverts commit a51d0fea6880046300fcf466a767f88eab9a6f9a. | ||||
* | Move network-config.h to the top of the testsuite include path. | Chris Johns | 2016-05-06 | 1 | -1/+1 |
* | Add sbin/sysctl | Chris Johns | 2016-05-06 | 1 | -0/+3 |
* | Add RealTek Gig PHY. | Chris Johns | 2016-05-04 | 1 | -0/+2 |
* | Delete dummy IRQ support | Sebastian Huber | 2016-04-27 | 1 | -4/+0 |
| | | | | | Architectures and BSPs which want to use libbsd must provide the required interfaces. | ||||
* | Add root bus support functions | Sebastian Huber | 2016-04-26 | 1 | -0/+1 |
* | Initialize interrupt server early | Sebastian Huber | 2016-04-26 | 1 | -0/+1 |
| | | | | This enables its use before the Nexus device exists. | ||||
* | waf: Check for no FreeBSD options being supplied. | Chris Johns | 2016-04-26 | 1 | -2/+3 |
* | waf: Add the ability to set FreeBSD options on the configure command line. | Chris Johns | 2016-04-23 | 1 | -33/+39 |
| | | | | | Add --freebsd-options to add specific FreeBSD compile time options to the build. This is a developer tool. | ||||
* | waf: Move the generated content to libbsd_waf.py. | Chris Johns | 2016-04-20 | 1 | -0/+1395 |
