* | Add VDE and QEMU doco. | Chris Johns | 2016-06-27 | 1 | -0/+51 |
* | Fix spelling. | Chris Johns | 2016-06-27 | 1 | -1/+1 |
* | libbsd.txt: Clarify xilinx_zynq_a9_qemu usage | Sebastian Huber | 2016-06-13 | 1 | -10/+22 |
* | libbsd.txt: Fix format | Sebastian Huber | 2016-06-10 | 1 | -0/+1 |
* | Add a stats report command. | Chris Johns | 2016-05-31 | 1 | -2/+16 |
| | | | | The report shows the level of changes we have made to the FreeBSD code. | ||||
* | Add rc.conf documentation. | Chris Johns | 2016-05-18 | 1 | -1/+50 |
* | Add "How to import code from FreeBSD" | Sebastian Huber | 2016-05-06 | 1 | -0/+14 |
* | Add script to create the kernel namespace header | Sebastian Huber | 2016-05-06 | 1 | -0/+1 |
* | Add some doco on reverse and forward movement of the code. | Chris Johns | 2016-05-04 | 1 | -1/+26 |
* | Add RTEMS version support, update all python to 2 and 3. | Chris Johns | 2016-04-18 | 1 | -63/+29 |
| | | | | | | | | | | | | | Add support to force the RTEMS version. This remove the need for using the --rtems-version command line option if the automatic detection fails. Update all python code to support python 2 and 3. Update rtems_waf to the latest version to support the RTEMS version, check environment variables and to display the CC version. Sort all tests. I think the unsorted list is dependent on the version of python and so would result in repo noise as if it regenerted. | ||||
* | doc: Qemu network | Sebastian Huber | 2015-10-01 | 1 | -0/+9 |
* | doc: Add Qemu network setup | Sebastian Huber | 2015-10-01 | 1 | -0/+49 |
* | i386: Quick and dirty hack to get PCI working | Sebastian Huber | 2015-09-30 | 1 | -0/+2 |
* | libbsd.txt: Clarify rules to modify FreeBSD code | Sebastian Huber | 2015-07-15 | 1 | -3/+13 |
* | Update libbsd.txt with Xilinx Zynq TXCSUM and RXCSUM controls. | Chris Johns | 2015-06-22 | 1 | -1/+13 |
* | Revert "Return the default TX and RX hardware checksum for the Cadence ↵ | Chris Johns | 2015-06-22 | 1 | -13/+1 |
| | | | | | | | | | driver to off." This reverts commit 54fb9f01f86286ecea3093f6f524afec86d6313f. This change adds white space changes. A better solution is to revert the original change. | ||||
* | Return the default TX and RX hardware checksum for the Cadence driver to off. | Chris Johns | 2015-06-19 | 1 | -1/+13 |
| | | | | | | The hardware support does not seem to work with qemu. The support can be enabled with ifconfig or via ioctl on real hardware to get the performance boost. | ||||
* | Update LibBSD doco. | Chris Johns | 2015-06-01 | 1 | -108/+115 |
* | SLEEPQUEUE(9): Port to RTEMS | Sebastian Huber | 2015-03-24 | 1 | -0/+2 |
* | Add and use rtems_bsd_get_allocator_domain_size() | Sebastian Huber | 2015-02-13 | 1 | -0/+8 |
* | Add and use rtems_bsd_get_task_stack_size() | Sebastian Huber | 2015-01-20 | 1 | -0/+4 |
* | Add and use rtems_bsd_get_task_priority() | Sebastian Huber | 2015-01-20 | 1 | -0/+8 |
* | HOSTNAME(1): Add -m flag | Sebastian Huber | 2014-11-20 | 1 | -0/+9 |
* | doc: Add network interface link up/down hint | Sebastian Huber | 2014-10-16 | 1 | -0/+11 |
* | doc: Clarify initialization | Sebastian Huber | 2014-05-16 | 1 | -7/+51 |
* | doc: Clarify test run | Sebastian Huber | 2014-05-16 | 1 | -0/+16 |
* | doc: Clarify linkcmds sections | Sebastian Huber | 2014-05-16 | 1 | -3/+5 |
* | doc: Fix link and header | Christian Mauderer | 2014-05-16 | 1 | -2/+3 |
* | Add some installation hints | Sebastian Huber | 2014-05-14 | 1 | -0/+11 |
* | Documentation | Sebastian Huber | 2014-01-30 | 1 | -220/+348 |
* | PRINTF(9): Do not use printk() for log() | Sebastian Huber | 2014-01-30 | 1 | -0/+3 |
| | | | | | The BSD library functions must use printk(). The %D format specifier is not supported, thus we cannot use the printf() family for output. | ||||
* | UNIX(4): Import from FreeBSD | Sebastian Huber | 2014-01-16 | 1 | -0/+4 |
* | BPF(4): Add support | Sebastian Huber | 2013-12-16 | 1 | -0/+2 |
* | Use a local MSIZE of 256 | Sebastian Huber | 2013-11-04 | 1 | -0/+2 |
* | PING6(8): Add TODO | Sebastian Huber | 2013-10-31 | 1 | -0/+2 |
* | Implement sysctl_handle_opaque() | Sebastian Huber | 2013-10-31 | 1 | -0/+2 |
| | | | | FIXME: The snapshots are not reliable. | ||||
* | TIMEOUT(9): Use timer server for callout_tick() | Sebastian Huber | 2013-10-31 | 1 | -0/+3 |
* | Use kqueue() and kevent() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+2 |
* | TASKQUEUE(9): Use FreeBSD implementation | Sebastian Huber | 2013-10-31 | 1 | -1/+3 |
* | ZONE(9): Add and use red-black tree chunk alloc | Sebastian Huber | 2013-10-31 | 1 | -0/+2 |
* | Add TODO for priority values | Sebastian Huber | 2013-10-31 | 1 | -0/+3 |
* | Add TODO item | Sebastian Huber | 2013-10-31 | 1 | -0/+2 |
* | IFCONFIG(8): Disable IEEE80211 support | Sebastian Huber | 2013-10-31 | 1 | -0/+3 |
| | | | | This module depends on a XML parser and mmap(). | ||||
* | Add MAC support functions | Sebastian Huber | 2013-10-31 | 1 | -0/+2 |
| | | | | WARNING: They are not thread-safe! This is a known FreeBSD issue. | ||||
* | Disable user credentials and use default values | Sebastian Huber | 2013-10-31 | 1 | -0/+8 |
* | Use default PID value for all process identifiers | Sebastian Huber | 2013-10-31 | 1 | -0/+3 |
* | Disable alternative routing tables | Sebastian Huber | 2013-10-31 | 1 | -0/+3 |
* | Avoid per-CPU NETISR(9) | Sebastian Huber | 2013-10-10 | 1 | -0/+4 |
| | | | | SMP support should be enabled once the new stack is ready for this. | ||||
* | Add FreeBSD sources as a submodule | Sebastian Huber | 2013-10-08 | 1 | -7/+6 |
| | | | | | | The current version corresponds to SVN r255967 of: http://svn.freebsd.org/base/releng/8.2 | ||||
* | Added more information on MMAP_NOT_AVAILABLE. | Jennifer Averett | 2012-10-05 | 1 | -0/+2 |
