* | SLEEPQUEUE(9): Port to RTEMS | Sebastian Huber | 2015-03-24 | 1 | -0/+2 |
* | Add and use rtems_bsd_get_allocator_domain_size() | Sebastian Huber | 2015-02-13 | 1 | -0/+8 |
* | Add and use rtems_bsd_get_task_stack_size() | Sebastian Huber | 2015-01-20 | 1 | -0/+4 |
* | Add and use rtems_bsd_get_task_priority() | Sebastian Huber | 2015-01-20 | 1 | -0/+8 |
* | HOSTNAME(1): Add -m flag | Sebastian Huber | 2014-11-20 | 1 | -0/+9 |
* | doc: Add network interface link up/down hint | Sebastian Huber | 2014-10-16 | 1 | -0/+11 |
* | doc: Clarify initialization | Sebastian Huber | 2014-05-16 | 1 | -7/+51 |
* | doc: Clarify test run | Sebastian Huber | 2014-05-16 | 1 | -0/+16 |
* | doc: Clarify linkcmds sections | Sebastian Huber | 2014-05-16 | 1 | -3/+5 |
* | doc: Fix link and header | Christian Mauderer | 2014-05-16 | 1 | -2/+3 |
* | Add some installation hints | Sebastian Huber | 2014-05-14 | 1 | -0/+11 |
* | Documentation | Sebastian Huber | 2014-01-30 | 1 | -220/+348 |
* | PRINTF(9): Do not use printk() for log() | Sebastian Huber | 2014-01-30 | 1 | -0/+3 |
| | | | | | The BSD library functions must use printk(). The %D format specifier is not supported, thus we cannot use the printf() family for output. | ||||
* | UNIX(4): Import from FreeBSD | Sebastian Huber | 2014-01-16 | 1 | -0/+4 |
* | BPF(4): Add support | Sebastian Huber | 2013-12-16 | 1 | -0/+2 |
* | Use a local MSIZE of 256 | Sebastian Huber | 2013-11-04 | 1 | -0/+2 |
* | PING6(8): Add TODO | Sebastian Huber | 2013-10-31 | 1 | -0/+2 |
* | Implement sysctl_handle_opaque() | Sebastian Huber | 2013-10-31 | 1 | -0/+2 |
| | | | | FIXME: The snapshots are not reliable. | ||||
* | TIMEOUT(9): Use timer server for callout_tick() | Sebastian Huber | 2013-10-31 | 1 | -0/+3 |
* | Use kqueue() and kevent() from FreeBSD | Sebastian Huber | 2013-10-31 | 1 | -0/+2 |
* | TASKQUEUE(9): Use FreeBSD implementation | Sebastian Huber | 2013-10-31 | 1 | -1/+3 |
* | ZONE(9): Add and use red-black tree chunk alloc | Sebastian Huber | 2013-10-31 | 1 | -0/+2 |
* | Add TODO for priority values | Sebastian Huber | 2013-10-31 | 1 | -0/+3 |
* | Add TODO item | Sebastian Huber | 2013-10-31 | 1 | -0/+2 |
* | IFCONFIG(8): Disable IEEE80211 support | Sebastian Huber | 2013-10-31 | 1 | -0/+3 |
| | | | | This module depends on a XML parser and mmap(). | ||||
* | Add MAC support functions | Sebastian Huber | 2013-10-31 | 1 | -0/+2 |
| | | | | WARNING: They are not thread-safe! This is a known FreeBSD issue. | ||||
* | Disable user credentials and use default values | Sebastian Huber | 2013-10-31 | 1 | -0/+8 |
* | Use default PID value for all process identifiers | Sebastian Huber | 2013-10-31 | 1 | -0/+3 |
* | Disable alternative routing tables | Sebastian Huber | 2013-10-31 | 1 | -0/+3 |
* | Avoid per-CPU NETISR(9) | Sebastian Huber | 2013-10-10 | 1 | -0/+4 |
| | | | | SMP support should be enabled once the new stack is ready for this. | ||||
* | Add FreeBSD sources as a submodule | Sebastian Huber | 2013-10-08 | 1 | -7/+6 |
| | | | | | | The current version corresponds to SVN r255967 of: http://svn.freebsd.org/base/releng/8.2 | ||||
* | Added more information on MMAP_NOT_AVAILABLE. | Jennifer Averett | 2012-10-05 | 1 | -0/+2 |
* | rec_close.c: Removed usage of munmap() method. | Jennifer Averett | 2012-09-13 | 1 | -0/+9 |
| | | | | | | Note that there is a define MMAP_NOT_AVAILABLE that when NOT defined results in mmap not being called but munmap is still called. A comment was also added to our notes about this. | ||||
* | libbsd.txt: Update some status | Joel Sherrill | 2012-07-28 | 1 | -11/+14 |
* | Clarified information in libbsd.txt. | Kevin Polulak | 2012-07-11 | 1 | -16/+17 |
* | Added pcib for Nics. | Jennifer Averett | 2012-05-23 | 1 | -6/+19 |
* | Added Nic status section to documention. | Jennifer Averett | 2012-05-10 | 1 | -1/+22 |
* | Added documentation on rtems specific files. | Jennifer Averett | 2012-05-08 | 1 | -0/+193 |
* | Add "Core FreeBSD APIs and RTEMS Replacements" | Sebastian Huber | 2012-04-18 | 1 | -0/+99 |
* | Explain why we need the interrupt server | Sebastian Huber | 2012-04-16 | 1 | -1/+13 |
* | Elaborate RTEMS libbsd initialization | Sebastian Huber | 2012-04-16 | 1 | -11/+126 |
* | Add SVN checkout command description | Sebastian Huber | 2012-04-16 | 1 | -1/+4 |
* | Add example on SYSCTL_NODE expansion for _bsd_sysctl__net_children | Joel Sherrill | 2012-03-27 | 1 | -0/+43 |
* | Add information on ISA drivers not being ported initially | Joel Sherrill | 2012-03-22 | 1 | -0/+6 |
* | Add diff mode to freebsd-to-rtems.py | Joel Sherrill | 2012-03-12 | 1 | -0/+4 |
* | Add description of forward/reverse mode of script | Joel Sherrill | 2012-03-12 | 1 | -3/+56 |
* | Add URL to FreeBSD SVN tarball. | Joel Sherrill | 2012-03-09 | 1 | -1/+2 |
* | Add more details to documentation. | Joel Sherrill | 2012-03-09 | 1 | -5/+54 |
* | Documentation additions. | Joel Sherrill | 2012-03-09 | 1 | -1/+68 |
* | Initial addition of documentation | Joel Sherrill | 2012-03-09 | 1 | -0/+94 |
