* | NVD(4): Add RTEMS-specific NVMe disk driver | Sebastian Huber | 2019-11-13 | 1 | -0/+6 |
| | | | | Update #3821. | ||||
* | NVME(4): Install header files | Sebastian Huber | 2019-11-13 | 1 | -0/+1 |
* | NVME(4): Add build module | Sebastian Huber | 2019-11-13 | 1 | -0/+30 |
* | Remove obsolete header files | Sebastian Huber | 2019-09-25 | 1 | -1/+0 |
* | Fix pgsigio() warnings | Sebastian Huber | 2019-09-25 | 1 | -1/+0 |
* | Update to FreeBSD stable/12 2019-09-23 | Sebastian Huber | 2019-09-23 | 1 | -0/+2 |
| | | | | Git mirror commit 7e8d1444023128d34fb9aa4e4515928a4f794d1b. | ||||
* | PCI(4): Import missing file | Sebastian Huber | 2019-09-23 | 1 | -1/+2 |
* | PCI(4): Install header files | Sebastian Huber | 2019-09-23 | 1 | -0/+1 |
* | Add <sys/disk.h> to build module | Sebastian Huber | 2019-09-23 | 1 | -0/+1 |
* | Remove superfluous support for preloaded modules | Sebastian Huber | 2019-08-27 | 1 | -1/+0 |
* | Import missing header file | Sebastian Huber | 2019-06-28 | 1 | -0/+1 |
* | Update to FreeBSD stable/12 2019-06-05 | Sebastian Huber | 2019-06-05 | 1 | -4/+15 |
| | | | | Git mirror commit 78576620f2689e23144a1cf1bf55106cc6abe2b7. | ||||
* | Add riscv support | Sebastian Huber | 2019-05-23 | 1 | -1/+1 |
* | Update to FreeBSD stable/12 2019-03-27 | Sebastian Huber | 2019-03-28 | 1 | -0/+3 |
| | | | | Git mirror commit 43a38f188ca2e936ec78104c30ea3e24d9c1606b. | ||||
* | build: Add RTEMS test library | Sebastian Huber | 2019-03-28 | 1 | -2/+2 |
| | | | | Update #3199. | ||||
* | bin/openssl: Port to RTEMS. | Christian Mauderer | 2019-03-28 | 1 | -0/+92 |
* | Build C++ kernel-space compatibility file | Sebastian Huber | 2019-02-18 | 1 | -0/+1 |
* | mghttpd: Remove | Sebastian Huber | 2019-02-12 | 1 | -19/+0 |
| | | | | The mghttpd is already provided by RTEMS. | ||||
* | Update to FreeBSD stable/12 2019-02-11 | Sebastian Huber | 2019-02-12 | 1 | -0/+1 |
| | | | | Git mirror commit 606b591dae1023a71ff020faf99789059eb6591f. | ||||
* | Update to FreeBSD stable/12 2019-01-16 | Sebastian Huber | 2019-01-21 | 1 | -3/+1 |
| | | | | | | Git mirror commit 4ff7d8141f665693dd8b17090d410604888f1e9a. Update #3472. | ||||
* | freebsd/if_cpsw: Port. | Christian Mauderer | 2018-12-20 | 1 | -0/+3 |
* | Update to FreeBSD head 2018-11-15 | Sebastian Huber | 2018-11-15 | 1 | -1/+2 |
| | | | | | | Git mirror commit a18b0830c4be01b39489a891b63d6023ada6358a. Update #3472. | ||||
* | openssl01: New test | Sebastian Huber | 2018-10-25 | 1 | -0/+1 |
* | Update to FreeBSD head 2018-10-23 | Sebastian Huber | 2018-10-25 | 1 | -876/+838 |
| | | | | | | | | | | | Git mirror commit 59f44d20be3f99d181ca742e636d45fc39ec982b. This commit updates OpenSSL to version 1.1.1. This required an update of racoon which uses some internal stuff from OpenSSL and seems to be mostly unmaintained, e.g. there is update in the FreeBSD ports to cope with OpenSSL 1.1.1. Update #3472. | ||||
* | Add PHY-driver for KSZ8091RNB with 50MHz. | Christian Mauderer | 2018-09-27 | 1 | -0/+6 |
| | | | | | This adds a driver for the KSZ8091RNB PHY. This PHY needs some special treatment if it is clocked with a 50MHz clock. | ||||
* | fsl_sdhci.c: Port to RTEMS | Sebastian Huber | 2018-09-25 | 1 | -0/+1 |
| | | | | Update #3525. | ||||
* | imx/imx_gpio.c: Port to RTEMS | Sebastian Huber | 2018-09-25 | 1 | -4/+5 |
* | CONFIG_INTRHOOK(9): Port to RTEMS | Sebastian Huber | 2018-09-25 | 1 | -1/+1 |
| | | | | | | | | | Some device drivers (e.g. MMC) need a complex intialization with working callouts. Remove the dummy CONFIG_INTRHOOK() implementation and replace it with the real one from FreeBSD. Make sure TIMEOUT(9) services work at this point. Update #3525. | ||||
* | ck: Install header files | Sebastian Huber | 2018-09-24 | 1 | -0/+1 |
* | if_ffec_mpc8xx: Port driver to libbsd | Sebastian Huber | 2018-09-21 | 1 | -0/+1 |
| | | | | Update #3523. | ||||
* | Update to FreeBSD head 2018-09-17 | Sebastian Huber | 2018-09-21 | 1 | -261/+293 |
| | | | | | | Git mirror commit 6c2192b1ef8c50788c751f878552526800b1e319. Update #3472. | ||||
* | Update to FreeBSD head 2018-06-01 | Sebastian Huber | 2018-09-21 | 1 | -17/+58 |
| | | | | | | Git mirror commit fb63610a69b0eb7f69a201ba05c4c1a7a2739cf9. Update #3472. | ||||
* | Update to FreeBSD head 2018-04-01 | Sebastian Huber | 2018-09-21 | 1 | -36/+45 |
| | | | | | | Git mirror commit 8dfb1ccc26d1cea7e2529303003ff61f9f1784c4. Update #3472. | ||||
* | Update to FreeBSD head 2018-02-01 | Sebastian Huber | 2018-09-21 | 1 | -12/+13 |
| | | | | | | Git mirror commit d079ae0442af8fa3cfd6d7ede190d04e64a2c0d4. Update #3472. | ||||
* | Update to FreeBSD head 2017-12-01 | Sebastian Huber | 2018-09-21 | 1 | -4/+8 |
| | | | | | | Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266. Update #3472. | ||||
* | Update to FreeBSD head 2017-10-01 | Sebastian Huber | 2018-09-21 | 1 | -1/+16 |
| | | | | | | Git mirror commit b2f0376b45428f13151d229c5ae9d4d8f74acbd1. Update #3472. | ||||
* | Update to FreeBSD head 2017-08-01 | Sebastian Huber | 2018-09-21 | 1 | -23/+28 |
| | | | | | | Git mirror commit f5002f5e5f78cae9f0269d812dc0aedb0339312c. Update #3472. | ||||
* | Update to FreeBSD head 2017-06-01 | Sebastian Huber | 2018-09-21 | 1 | -4/+0 |
| | | | | | | Git mirror commit dfb26efac4ce9101dda240e94d9ab53f80a9e131. Update #3472. | ||||
* | mDNSResponder: Update to v765.1.2 | Sebastian Huber | 2018-09-20 | 1 | -2/+3 |
| | | | | | | | | | | | | | The sources can be obtained via: https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-765.1.2.tar.gz Move mDNS_StartResolveService() and mDNS_StopResolveService() to an RTEMS-specific file (rtemsbsd/mdns/mDNSResolveService.c) using the v576.30.4 implementation. Apple removed these functions without explanation. Update #3522. | ||||
* | Move dynamic mutex pool to separate file | Sebastian Huber | 2018-09-12 | 1 | -0/+1 |
| | | | | This avoids false link-time dependencies. | ||||
* | WPA_SUPPLICANT(8): Remove unused files | Sebastian Huber | 2018-08-24 | 1 | -2/+0 |
| | | | | | | | Remove unused files which may make trouble during FreeBSD baseline updates. It also increased the compile-time of the library for nothing. Update #3472. | ||||
* | IPFW(4): Remove FreeBSD import | Sebastian Huber | 2018-08-24 | 1 | -55/+1 |
| | | | | | | | | This firewall was not ported to RTEMS and is just dead code which may make trouble during FreeBSD baseline updates. It also increased the compile-time of the library for nothing. Update #3472. | ||||
* | testsuite/ipsec01: Add. | Christian Mauderer | 2018-08-02 | 1 | -0/+1 |
* | Add ipsec to rc.conf. | Christian Mauderer | 2018-08-02 | 1 | -0/+7 |
* | ipsec-tools: Port libipsec, setkey and racoon. | Christian Mauderer | 2018-08-02 | 1 | -18/+157 |
| | | | | | Note that this replaces the libipsec from FreeBSD with the one provided by ipsec-tools. | ||||
* | if_ipsec: Port and add to everything-buildset. | Christian Mauderer | 2018-08-01 | 1 | -0/+2 |
| | | | | | This ports the kernel space parts for ipsec and adds them to the everything-buildset. | ||||
* | dhcpcd: Add hooks | Sebastian Huber | 2018-05-08 | 1 | -0/+1 |
* | waf: Allow to add libs per test. | Christian Mauderer | 2018-05-04 | 1 | -10/+23 |
| | | | | Update #3419. | ||||
* | buildset: Add minimal and everything config. | Christian Mauderer | 2018-05-03 | 1 | -6/+4 |
| | | | | | | | | | | | | This adds two new buildset configurations: One that leaves out as much features as possible and one that enables all features. For the default configuration WiFi support is now disabled. To disable IPv6 for the minimal configuration, all -DINET6 are eliminated in libbsd.py. They are now replaced by a #ifdef that checks for RTEMS_BSD_MODULE_NETINET6 instead. Close #3351. | ||||
* | Use network services from RTEMS | Sebastian Huber | 2018-04-30 | 1 | -15/+0 |
| | | | | Close #3419. |
