Update #3199.
The mghttpd is already provided by RTEMS.
Git mirror commit 19a6ceb89dbacf74697d493e48c388767126d418.
It includes an update of wpa_supplicant to version 2.7.
It includes an update of the OpenSSL baseline to version 1.1.1a.
Update #3472.
Git mirror commit a18b0830c4be01b39489a891b63d6023ada6358a.
Update #3472.
Git mirror commit 59f44d20be3f99d181ca742e636d45fc39ec982b.
This commit updates OpenSSL to version 1.1.1. This required an update
of racoon which uses some internal stuff from OpenSSL and seems to be
mostly unmaintained, e.g. there is update in the FreeBSD ports to cope
with OpenSSL 1.1.1.
Update #3472.
This adds a driver for the KSZ8091RNB PHY. This PHY needs some special
treatment if it is clocked with a 50MHz clock.
Update #3525.
Update #3525.
Some device drivers (e.g. MMC) need a complex intialization with working
callouts. Remove the dummy CONFIG_INTRHOOK() implementation and replace
it with the real one from FreeBSD. Make sure TIMEOUT(9) services work
at this point.
Update #3525.
Update #3472.
Update #3523.
Git mirror commit 6c2192b1ef8c50788c751f878552526800b1e319.
Update #3472.
Git mirror commit fb63610a69b0eb7f69a201ba05c4c1a7a2739cf9.
Update #3472.
Git mirror commit 8dfb1ccc26d1cea7e2529303003ff61f9f1784c4.
Update #3472.
Git mirror commit d079ae0442af8fa3cfd6d7ede190d04e64a2c0d4.
Update #3472.
Git mirror commit e724f51f811a4b2bd29447f8b85ab5c2f9b88266.
Update #3472.
Git mirror commit b2f0376b45428f13151d229c5ae9d4d8f74acbd1.
Update #3472.
Git mirror commit f5002f5e5f78cae9f0269d812dc0aedb0339312c.
Update #3472.
Git mirror commit dfb26efac4ce9101dda240e94d9ab53f80a9e131.
Update #3472.
The sources can be obtained via:
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-765.1.2.tar.gz
Move mDNS_StartResolveService() and mDNS_StopResolveService() to an
RTEMS-specific file (rtemsbsd/mdns/mDNSResolveService.c) using the
v576.30.4 implementation. Apple removed these functions without
explanation.
Update #3522.
This avoids false link-time dependencies.
Remove unused files which may make trouble during FreeBSD baseline
updates. It also increased the compile-time of the library for nothing.
Update #3472.
This firewall was not ported to RTEMS and is just dead code which may
make trouble during FreeBSD baseline updates. It also increased the
Update #3472.
Note that this replaces the libipsec from FreeBSD with the one provided
by ipsec-tools.
This ports the kernel space parts for ipsec and adds them to the
everything-buildset.
Update #3419.
This adds two new buildset configurations: One that leaves out as much
features as possible and one that enables all features. For the default
configuration WiFi support is now disabled.
To disable IPv6 for the minimal configuration, all -DINET6 are
eliminated in libbsd.py. They are now replaced by a #ifdef that checks
for RTEMS_BSD_MODULE_NETINET6 instead.
Close #3351.
Close #3419.
Update #3351
There are no imported sources for a number of modules. Some of them
doesn't even have the right paths for freebsd-org anymore. Therefore
this patch removes the following modules:
- dev_usb_add_on
- dev_usb_bluetooth
- dev_usb_controller_add_on
- dev_usb_misc
- dev_usb_storage_add_on
- dev_usb_template
- dev_nic_cs
Update #3351
This change allows us to control the modules we want to build.
Update #3351
Remove the need to generate a waf script.
Move various pieces of data from the builder code to libbsd.py and make
it configuration data.
Update #3351
Some applications (like the civetweb web server) still use functions
that are deprecated by openssl. If OPENSSL_NO_DEPRECATED is defined,
openssl will not provide these functions. This patch removes the define
so that the functions are available.
Close #3290.
