* | pf: Add configuration via rc.conf. | Christian Mauderer | 2016-08-08 | 1 | -0/+1 |
* | freebsd: Add constant ipv6 addresses from vars.c. | Christian Mauderer | 2016-08-04 | 1 | -0/+1 |
| | | | | This is necessary for a configuration without IPv6. | ||||
* | testsuite/pf02: Add interactive pf test. | Christian Mauderer | 2016-08-03 | 1 | -0/+1 |
* | pfctl: build files. | Christian Mauderer | 2016-08-02 | 1 | -0/+17 |
* | testsuite/syscalls01: Split out program01 part. | Christian Mauderer | 2016-08-02 | 1 | -0/+1 |
| | | | | | | This allows to use normal functions for sockets and similar while allowing to test the upcoming rtems_bsd_program_opan/close/... for the program part. | ||||
* | testsuite/pf01: Add test that links PF. | Christian Mauderer | 2016-08-01 | 1 | -0/+1 |
* | testsuite/cdev01: Add test for cdev functions. | Christian Mauderer | 2016-08-01 | 1 | -0/+1 |
* | kern_conf.c: Adapt for RTEMS. | Christian Mauderer | 2016-08-01 | 1 | -1/+1 |
* | rtemsbsd/devfs: Add. | Christian Mauderer | 2016-08-01 | 1 | -0/+1 |
* | Add telnetd as service to rc.conf. | Chris Johns | 2016-07-01 | 1 | -0/+2 |
* | Add RTEMS_BSD_CONFIG_DOMAIN_PAGE_MBUFS_SIZE. | Chris Johns | 2016-06-30 | 1 | -0/+1 |
| | | | | | The domain allocator page abd mbuf size can be configured by the user using RTEMS_BSD_CONFIG_DOMAIN_PAGE_MBUFS_SIZE. | ||||
* | Add rtems_get_route to fetch a specific route from the routing tables. | Chris Johns | 2016-06-30 | 1 | -0/+1 |
* | Add ftpd as a service. Add rtems-bsd-config.h for app libbsd set up. | Chris Johns | 2016-06-28 | 1 | -0/+2 |
* | Add a services base test. | Chris Johns | 2016-06-27 | 1 | -58/+59 |
* | nfsclient: Port to LibBSD | Sebastian Huber | 2016-06-10 | 1 | -0/+5 |
* | XDR(3): Port to RTEMS | Sebastian Huber | 2016-06-10 | 1 | -0/+8 |
* | RPC(3): Port to RTEMS | Sebastian Huber | 2016-06-10 | 1 | -11/+84 |
* | ftpfs: Import from RTEMS | Sebastian Huber | 2016-06-10 | 1 | -0/+2 |
| | | | | RTEMS Git commit 251c94d3d3d27e0039f01b718e5c2eb06f39fdf7. | ||||
* | Add support for rc.conf(5) initialisation. | Chris Johns | 2016-05-18 | 1 | -0/+3 |
| | | | | | | | | | | | | | | | | | | | | | | | | Provide user support for rc.conf(5) so a user can create a suitable /etc/rc.conf file to initialise libbsd. This patch by default adds basic networking support: cloned_interfaces ifconfig_'interface' defaultrouter hostname Refer to FreeBSD documentation for examples. Users can make a single call to have /etc/rc.conf processed, or pass a file name to a specific configuration file or a text string with line feeds can be passed to the scripting version of the interface. The rc.conf support is implemented in terms of directive handlers that are called based on a regular expression. The design allows new handlers to be added as needed. Line concatenation is still to be implemented. | ||||
* | Add namespace support for kvm | Sebastian Huber | 2016-05-06 | 1 | -1/+1 |
* | Rename files for kernel namespace script | Sebastian Huber | 2016-05-06 | 1 | -38/+38 |
| | | | | This makes it easier to create the kernel namespace header. | ||||
* | subr_prf.c: Port to RTEMS | Sebastian Huber | 2016-05-06 | 1 | -2/+4 |
* | Add sbin/sysctl | Chris Johns | 2016-05-06 | 1 | -0/+3 |
* | Add RealTek Gig PHY. | Chris Johns | 2016-05-04 | 1 | -0/+3 |
* | libbsd: Remove sys/select.h and sys/_sigset.h. | Chris Johns | 2016-04-27 | 1 | -2/+0 |
* | Add root bus support functions | Sebastian Huber | 2016-04-26 | 1 | -0/+1 |
* | Initialize interrupt server early | Sebastian Huber | 2016-04-26 | 1 | -0/+1 |
| | | | | This enables its use before the Nexus device exists. | ||||
* | Add RTEMS version support, update all python to 2 and 3. | Chris Johns | 2016-04-18 | 1 | -1/+7 |
| | | | | | | | | | | | | | Add support to force the RTEMS version. This remove the need for using the --rtems-version command line option if the automatic detection fails. Update all python code to support python 2 and 3. Update rtems_waf to the latest version to support the RTEMS version, check environment variables and to display the CC version. Sort all tests. I think the unsorted list is dependent on the version of python and so would result in repo noise as if it regenerted. | ||||
* | Use RTEMS provided <sys/priority.h> | Sebastian Huber | 2015-11-17 | 1 | -1/+0 |
* | Use RTEMS provided <sys/ttycom.h> | Sebastian Huber | 2015-11-17 | 1 | -1/+0 |
* | Use RTEMS provided <sys/sockio.h> | Sebastian Huber | 2015-11-17 | 1 | -1/+0 |
* | Use RTEMS provided <sys/mman.h> | Sebastian Huber | 2015-11-17 | 1 | -2/+0 |
* | Use RTEMS provided <sys/endian.h> | Sebastian Huber | 2015-11-17 | 1 | -1/+0 |
* | dwc_otg: Port to RTEMS | Sebastian Huber | 2015-11-12 | 1 | -0/+4 |
* | BUS_SPACE(9): Use FreeBSD files for i386 arch | Sebastian Huber | 2015-09-29 | 1 | -0/+2 |
* | Avoid pci_cfgreg.h rename | Sebastian Huber | 2015-09-29 | 1 | -8/+2 |
* | builder.py: addTargetSourceCPUDependentSourceFiles | Sebastian Huber | 2015-09-25 | 1 | -25/+12 |
| | | | | Avoid and delete this function. | ||||
* | Avoid pci_bus.c file rename | Sebastian Huber | 2015-09-25 | 1 | -8/+1 |
* | Delete superfluous pci_cfgreg.h files | Sebastian Huber | 2015-09-01 | 1 | -2/+1 |
* | Delete superfluous legacyvar.h files | Sebastian Huber | 2015-09-01 | 1 | -8/+0 |
* | Delete superfluous pci_bus.c files | Sebastian Huber | 2015-09-01 | 1 | -2/+1 |
* | Delete superfluous legacy.c files | Sebastian Huber | 2015-09-01 | 1 | -9/+0 |
* | e1000: Add missing file | Sebastian Huber | 2015-07-31 | 1 | -11/+12 |
* | TCPDUMP and PCAP fixes to defines. | Chris Johns | 2015-06-16 | 1 | -3/+11 |
* | Add tcpdump and libpcap. | Chris Johns | 2015-06-15 | 1 | -3/+321 |
| | | | | | | | | | - Update the file builder generator to handle generator specific cflags and includes. The tcpdump and libpcap have localised headers and need specific headers paths to see them. There are also module specific flags and these need to be passed to the lex and yacc generators. - Add the tcpdump support. | ||||
* | Add INVARIANTS support | Sebastian Huber | 2015-05-20 | 1 | -0/+1 |
* | Update due to API changes (timecounters) | Sebastian Huber | 2015-05-20 | 1 | -3/+0 |
* | usb: Import USB support from libusb | Sebastian Huber | 2015-05-15 | 1 | -2/+3 |
* | Disable IEEE 802.11 module | Sebastian Huber | 2015-05-15 | 1 | -1/+1 |
* | freebsd-to-rtems: Refactor the conversion support to allow multiples build ↵ | Chris Johns | 2015-05-15 | 1 | -0/+2300 |
systems. Split the freebsd-to-rtems.py into separate parts to allow more than a single build system generator. |
