* | i386: Add missing files to build system | Jan Sommer | 2020-09-16 | 1 | -3/+7 |
| | | | | | - Update FreeBSD files in libbsd.py to required by i386 based BSPs - Add missing files e1000 network driver (iflib*) | ||||
* | waf: Implement module dependency checking in the build system | Chris Johns | 2020-09-16 | 1 | -15/+14 |
| | | | | | | | | | - Do not build a test if a dependency is not enabled. - Perform a dependency check and generate an error if an enabled module depends on a disabled module. Closes #4077 | ||||
* | build: Separate the kernel and user land include paths | Chris Johns | 2020-09-16 | 1 | -230/+309 |
| | | | | | | | | | | | | | | | | | | | | | | | - Provide support for separate user and kernel include paths in libbsd.py. - Update all added files with a suitable context to build them with. Supported contexts are `kernel` and `user`. - Kernel source use the kernel, CPU, and build header paths in this order. - User source use the user, kernel, CPU and build header paths in this order. The FreeBSD /usr/include tree has some kernel header files installed as well as user land header files. This complicates the separation as some kernel header files are not visible to user land code while other are. This is handled by appending the kernel header paths to the user header paths so user land code will include a user header with the same name as a kernel header over the kernel header but will find a kernel header if there is no matching user header file. Closes #4067 | ||||
* | mcast01: Add test program | Sebastian Huber | 2020-09-10 | 1 | -0/+1 |
* | ifmcstat: Port to RTEMS | Sebastian Huber | 2020-09-10 | 1 | -0/+3 |
* | imx: Use RTEMS GPIO driver instead of FreeBSD one | Christian Mauderer | 2020-07-29 | 1 | -1/+1 |
| | | | | Update 3869 | ||||
* | gpioregulator: Remove. | Christian Mauderer | 2020-07-29 | 1 | -1/+0 |
| | | | | | | | | | There is a bug in the #ifdef regarding FDT so this file hasn't been compiled. If that bug is solved, the driver doesn't work for some other reason. With the FDT-bug the driver hasn't been used by anyone. So just remove it again. | ||||
* | libbsd.py: Install the evdev header files5.35.25.15 | Vijay Kumar Banerjee | 2020-06-04 | 1 | -0/+1 |
* | ehci_imx: Add to build. | Christian Mauderer | 2020-04-15 | 1 | -0/+2 |
* | regulator: Add to build. | Christian Mauderer | 2020-04-15 | 1 | -0/+30 |
| | | | | Update #3869. | ||||
* | imx6_ccm: Add and build module. | Christian Mauderer | 2020-04-15 | 1 | -0/+23 |
* | waf: Change the test configure check for libdebugger to it's lib | Chris Johns | 2020-03-05 | 1 | -2/+2 |
| | | | | | | | | | - Add support for a 'test-if-library' - Use rtems_waf's 'test_application()' fragment in the check_cc call Closes #3948 | ||||
* | i386: Add to build | Jan Sommer | 2020-02-10 | 1 | -2/+5 |
* | SOCKATMARK(3): Import from FreeBSD | Sebastian Huber | 2019-12-19 | 1 | -0/+1 |
| | | | | Update #3798. | ||||
* | NVMECONTROL(8): Port to RTEMS | Sebastian Huber | 2019-11-13 | 1 | -0/+1 |
| | | | | Update #3821. | ||||
* | NVMECONTROL(8): Add to build | Sebastian Huber | 2019-11-13 | 1 | -0/+31 |
* | NVD(4): Add RTEMS-specific NVMe disk driver | Sebastian Huber | 2019-11-13 | 1 | -0/+6 |
* | NVME(4): Install header files | Sebastian Huber | 2019-11-13 | 1 | -0/+1 |
* | NVME(4): Add build module | Sebastian Huber | 2019-11-13 | 1 | -0/+30 |
* | Update to FreeBSD head 2019-09-24 | Sebastian Huber | 2019-11-13 | 1 | -83/+92 |
| | | | | Git mirror commit 6b0307a0a5184339393f555d5d424190d8a8277a. | ||||
* | Remove obsolete header files | Sebastian Huber | 2019-09-24 | 1 | -1/+0 |
* | Fix pgsigio() warnings | Sebastian Huber | 2019-09-24 | 1 | -1/+0 |
* | PCI(4): Import missing file | Sebastian Huber | 2019-09-23 | 1 | -1/+2 |
* | PCI(4): Install header files | Sebastian Huber | 2019-09-23 | 1 | -1/+2 |
* | Add <sys/disk.h> to build module | Sebastian Huber | 2019-09-23 | 1 | -0/+1 |
* | rtemsbsd: remove dead code fb.c | Vijay Kumar Banerjee | 2019-08-31 | 1 | -1/+0 |
* | Remove superfluous support for preloaded modules | Sebastian Huber | 2019-08-27 | 1 | -1/+0 |
* | am335x display drivers: Port to RTEMS | Vijay Kumar Banerjee | 2019-08-11 | 1 | -0/+5 |
* | fbd: Port to RTEMS | Vijay Kumar Banerjee | 2019-08-11 | 1 | -0/+11 |
* | TDA19988: Port to RTEMS | Vijay Kumar Banerjee | 2019-08-11 | 1 | -0/+41 |
* | Pinmux: Port to RTEMS | Vijay Kumar Banerjee | 2019-08-11 | 1 | -0/+33 |
* | i2c tool : port to RTEMS | Vijay Kumar Banerjee | 2019-06-29 | 1 | -0/+2 |
* | Add rtems i2c adaptation layer | Vijay Kumar Banerjee | 2019-06-29 | 1 | -0/+1 |
* | iicbus: port to RTEMS | Vijay Kumar Banerjee | 2019-06-29 | 1 | -0/+35 |
* | Add riscv support | Sebastian Huber | 2019-05-23 | 1 | -1/+1 |
* | Import FreeBSD license files. | Christian Mauderer | 2019-04-04 | 1 | -0/+45 |
* | build: Add RTEMS test library | Sebastian Huber | 2019-03-28 | 1 | -2/+2 |
| | | | | Update #3199. | ||||
* | bin/openssl: Port to RTEMS. | Christian Mauderer | 2019-03-27 | 1 | -0/+92 |
* | Build C++ kernel-space compatibility file | Sebastian Huber | 2019-02-18 | 1 | -0/+1 |
* | mghttpd: Remove | Sebastian Huber | 2019-02-12 | 1 | -19/+0 |
| | | | | The mghttpd is already provided by RTEMS. | ||||
* | Update to FreeBSD head 2018-12-20 | Sebastian Huber | 2018-12-20 | 1 | -72/+80 |
| | | | | | | | | | | Git mirror commit 19a6ceb89dbacf74697d493e48c388767126d418. It includes an update of wpa_supplicant to version 2.7. It includes an update of the OpenSSL baseline to version 1.1.1a. Update #3472. | ||||
* | freebsd/if_cpsw: Port. | Christian Mauderer | 2018-12-20 | 1 | -0/+3 |
* | Update to FreeBSD head 2018-11-15 | Sebastian Huber | 2018-11-15 | 1 | -1/+2 |
| | | | | | | Git mirror commit a18b0830c4be01b39489a891b63d6023ada6358a. Update #3472. | ||||
* | openssl01: New test | Sebastian Huber | 2018-10-25 | 1 | -0/+1 |
* | Update to FreeBSD head 2018-10-23 | Sebastian Huber | 2018-10-25 | 1 | -876/+838 |
| | | | | | | | | | | | Git mirror commit 59f44d20be3f99d181ca742e636d45fc39ec982b. This commit updates OpenSSL to version 1.1.1. This required an update of racoon which uses some internal stuff from OpenSSL and seems to be mostly unmaintained, e.g. there is update in the FreeBSD ports to cope with OpenSSL 1.1.1. Update #3472. | ||||
* | Add PHY-driver for KSZ8091RNB with 50MHz. | Christian Mauderer | 2018-09-27 | 1 | -0/+6 |
| | | | | | This adds a driver for the KSZ8091RNB PHY. This PHY needs some special treatment if it is clocked with a 50MHz clock. | ||||
* | fsl_sdhci.c: Port to RTEMS | Sebastian Huber | 2018-09-25 | 1 | -0/+1 |
| | | | | Update #3525. | ||||
* | imx/imx_gpio.c: Port to RTEMS | Sebastian Huber | 2018-09-25 | 1 | -4/+5 |
* | CONFIG_INTRHOOK(9): Port to RTEMS | Sebastian Huber | 2018-09-25 | 1 | -1/+1 |
| | | | | | | | | | Some device drivers (e.g. MMC) need a complex intialization with working callouts. Remove the dummy CONFIG_INTRHOOK() implementation and replace it with the real one from FreeBSD. Make sure TIMEOUT(9) services work at this point. Update #3525. | ||||
* | ck: Install header files | Sebastian Huber | 2018-09-24 | 1 | -0/+1 |
| | | | | Update #3472. |
